QoS on NCS
BB7
Hello Experts,
I am trying to configure QoS on NCS router using the reference guide. It's a simple configuration with one class-map having one match condition and one policy-map.
RP/0/RP0/CPU0:router# configure
RP/0/RP0/CPU0:router(config)# class-map ipprec5
RP/0/RP0/CPU0:router(config-cmap)# match precedence ipv4 5
RP/0/RP0/CPU0:router(config-cmap)# exit
RP/0/RP0/CPU0:router(config)# policy-map policy1
RP/0/RP0/CPU0:router(config-pmap)# class ipprec5
RP/0/RP0/CPU0:router(config-pmap-c)# bandwidth 1000 mbps
RP/0/RP0/CPU0:router(config-pmap)# exit
RP/0/RP0/CPU0:router(config)# interface HundredGigabitEthernet  0/1/0/9
RP/0/RP0/CPU0:router(config-if)# service-policy input policy1
According to the link: https://www.cisco.com/c/en/us/td/docs/iosxr/ncs5500/qos/b-ncs5500-qos-cli-reference/b-ncs5500-qos-cli-reference_chapter_01.html#wp1772137353, the ip precedence match condition is supported in ingress direction. But after commiting the above config I am getting the following errors
service-policy input policy5
!!% 'DNX_QOSEA' detected the 'warning' condition 'Unsupported action type for ingress.
Any help would be appreciated?
Thanks.
Hello
I have same problem, getting the same message while for me, I want to shape traffic over EVC.
is there some one who can help ?
thank you
Joseph W. Doherty
I'm unfamiliar with the NCS, but in general, you cannot have a class bandwidth statement within an ingress policy.
Hi all
I have the same problem and till now, I dont find the solution, let me explain the situation.
We have N540-24Z8Q2C-Mand ASR 920 into our Carrier Ethernet Network, we provide, E-line over EVC to customers for instance to interconnect their branch offices, and we need to shape traffic in egress to commited rate, this is working on ASR 920, but on NCS 540 I get below message
!!% 'DNX_QOSEA' detected the 'warning' condition 'Unsupported match type for egress.'
Find below my configuration, thank you for your suggestions
Best regards
class-map match-any ANY-TRAFFIC
match cos 0 1 2 3 4 5 6 7
end-class-map
policy-map 1G
class ANY-TRAFFIC
shape average 10 mbps
class class-default
end-policy-map
interface GigabitEthernet0/0/0/10
mtu 9230
interface GigabitEthernet0/0/0/10.200 l2transport
encapsulation dot1q 200
mtu 9230
l2vpn
xconnect group FSLNK00002
p2p FSLNK00002
interface GigabitEthernet0/0/0/15.200
neighbor ipv4 172.31.4.5 pw-id 200
RP/0/RP0/CPU0:host-1-ncs540(config-subif)#commit show-error
Fri Nov 29 23:04:32.299 CET
% Failed to commit one or more configuration items during a pseudo-atomic operation. All changes made have been reverted.
!! SEMANTIC ERRORS: This configuration was rejected by
!! the system due to semantic errors. The individual
!! errors with each failed configuration command can be
!! found below.
service-policy output 10M
end
As it appears you're matching all CoS, have your tried any other matching, like all IP Prec or just use the class-default with the shaper there?
