QOS on portchannel on 7609 routes
ullasupendran
Hi all
I am trying to have the following QOS parameters applied on a portchannel interface on my 7609 router.
I am getting the below mentioned error.Any suggestions in this regard will be appreciated.
class-map match-any cos7
match cos 7
class-map match-any cos6
match cos 6
class-map match-any cos1
match cos 1
class-map match-any cos0
match cos 0
class-map match-any cos4or5
match cos 4
match cos 5
class-map match-any cos2or3
match cos 2
match cos 3
policy-map AAV-downlink-child
class cos7
police 2000000
priority
queue-limit 128 packets
class cos6
bandwidth percent 36
class cos4or5
bandwidth percent 20
class cos2or3
bandwidth percent 15
class cos1
bandwidth percent 4
class cos0
bandwidth percent 4
queue-limit 1024 packets
policy-map AAV-downlink-50M
class class-default
shape average 50000000
service-policy AAV-downlink-child
interface Port-channel10
description LACP Group ID 1
ip address 10.41.193.129 255.255.255.252
no ip redirects
ip ospf cost 10
mls qos trust dscp
interface GigabitEthernet1/6
no ip address
mls qos trust dscp
channel-group 10 mode active
interface GigabitEthernet1/7
no ip address
mls qos trust dscp
Router(config-if)#int port-channel 10
Router(config-if)#service-policy output AAV-downlink-50M
shape average command is not supported in output direction for this interface
Configuration failed!
Router(config-if)#service-policy input AAV-downlink-50M
shape average command is not supported in input direction for this interface
Router(config-if)#
Kind regards
Ullas
Edison Ortiz
Ullas,
You are facing a limitation on the hardware as regular line cards do not support egress shaping.
For shaping on egress, you need a WAN module (SIP/SPA or FlexWAN).
Edison.
HI edison
Dou you meant to say it wornt support ingress shaping too? it was not taking the service policy input also....
Ullas
You aren't allowed to shape on ingress even with a WAN module. Shaping can only be done on egress. However, you can police on ingress and egress with the regular line card.
Edison.
Thank you Edison.Rated as deserved.
Ullas
