02-19-2015 01:04 PM - edited 03-05-2019 12:50 AM
I'm running into an Qos problem. I noticed the Qos on the routers at my company needs to changed. It looks like the Meta traffic is merging into the voice traffic. The Qos policy is not applied to the serial interface on the router. I have recommendation but I would like a second pair of eyes.
class-map match-any VoIP-Signaling-and-Meta
match ip dscp af31
match ip dscp cs3
match access-group name Meta
class-map match-any Meta
class-map match-all VoIP-Traffic
match ip dscp ef
match ip dscp af31
match ip dscp cs3
class-map match-any Applications
match access-group name Applications
policy-map MARK-COS2
class VoIP-Signaling
class CitrixApps
set ip dscp af32
policy-map VoIP-QoS
class VoIP-Traffic
priority percent 30
class VoIP-Signaling-and-Meta
bandwidth remaining percent 40
service-policy MARK-COS2
class Application
bandwidth remaining percent 30
set ip dscp af21
class class-default
fair-queue
random-detect dscp-based
interface Serial0/0/0
bandwidth 1536
service-policy output VoIP-QoS
Recommend
match ip dscp ef
match ip dscp af31
match ip dscp cs3
match access-group name VoIP
match ip dscp af21
policy-map VoIP-QoS
class VoIP-Traffic
priority percent 40
set ip dscp af31
class Meta
set ip dscp ef
class Application
set ip dscp af21
class class-default
fair-queue
service-policy VoIP-QoS
02-20-2015 05:39 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
The original policy is questionable, but (I'm sorry to say) your new policy is possibly even more so.
VoIP signalling traffic and Meta traffic do share a class in the original policy, but it's unclear this would be a problem as VoIP bearer traffic does not.
BTW, no class-map for CitrixApps?
Also BTW, FQ and WRED, in the original policy, can make for some issues (FQ depends on the version of CBWFQ being used, pre or post HQF; optimal WRED usage really needs a QoS expert).
02-20-2015 01:13 PM
Thank you for responding. Your correct. I placed the wrong recommend.
Recommend
match ip dscp af31
match ip dscp ef
match ip dscp af21
policy-map VoIP-QoS
class VoIP-Traffic
priority percent 40
set ip dscp ef
class Meta
set ip dscp af31
class Application
set ip dscp af21
class class-default
fair-queue
02-21-2015 05:42 AM
Disclaimer
Posting
Now you have a "recursive" service-policy. Hmm, unsure a router would accept, and if it did, I have know idea how it would behave.
I'm also unsure you understand how the original service policy functions. But whether you do or don't, when forming QoS policies, it helps if you can state what the QoS policy is to accomplish. Then others might comment on whether the QoS policy makes sense and/or whether any actual policy configuration meets the goals.
