QOS Setup
Dear All,
Client was asking us to enable the port 55001 and 55002 to run on QOS on the WAN Link. Kindly advise how to configure and enable the port. Thank You.
policy-map QOS
 class SilverAF31-Map
  set ip dscp af31
   police cir percent 50 bc 300 ms pir percent 100 be 400 ms
     exceed-action set-dscp-transmit default
 class class-default
  fair-queue
Thank You..
Senthil R
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
It's unclear what is meant by enabling ports 55001 and 55002 and run QoS on the WAN link.
Do you want traffic using those ports to be classified, so QoS can treat that traffic differently?  If so, define a class-map matching an ACL that matches traffic with those ports.  Then treat the class as desired in your policy map.
