QoS urgent
mahesh_kv3
hai
I am working for an ISP so that i have put a 2 MB link to the customer router . since the customer is having video traffic i had pu t some policies in the customer end router .i had given precedence value 4 for the video traffic and remaining in class-default,after applying the policy map to the outside port(which is connected to the ISP) the availiable banwidth is showing 0 and getting the packet queued.the queing stratagy showing is weighted fair .so i tried to make it as fifo thru "no fair-qeue" then it is given that "must disable the CBWFQ"
I had given priority 1536 for video and remainin 512 MB for data
please help me to clear this problem
thanks in advance
Mahesh
royalblues
Level 10
Level 10
This is not a problem.. since you are using CBWFQ and have assigned all available bandwidth to the policy, the show interface would show it as zero
You need to use sh policy-map interface to see whether you are dropping traffic under the class
Narayan
nourelrayes
LLQ should be used when there is real time applications, it will give the video application a fixed strict bandwidth queue.
LFI also should be used to decrease the seialization delay.
Only 75% of the total availble bandwidth should be assigned to the classes created.
shiva_ial
mahesh,
I suggest you should do some modifications on the policy applied
as per your policy
voice class - 1548 kbps
data class - 512 kbps
totally accounts around 2048 kbps (2MB link)
you should understand,until you use max-reserved bandwidth command in the interface config you will have only 75% of bandwidth allocated to the policy which is 1.5 mbp approximately.
75% is cisco's recommendation(remaining 25% is used for routing & other protocol updates)
so you should have used max reserved bandwidth command to override this and use 2mb completely.
I hope,have answered you query.
rate if it helps
rgds/shiva
