QOS
vinayakrishna
Which queing and compression techniques are needed to effectively use the available bandwidth for voice traffic? (Choose the best Two)
A. CBWFQ
B. LLQ
C. PQ or CQ
D. RTP header compression
E. TCP header compression
royalblues
Level 10
Level 10
B & D would be my choice
Narayan
Pavel Bykov
Level 5
Level 5
B and D are actually the correct answers.
Wrong answers:
A: does not have a priority Queue
C: PQ is ok with policing (which is not mentioned) but CQ is not good for voice.
E: Voice uses extremely low bandwidth control data stream in TCP, that can tolerate loss and delay, so you needn't worry too much about TCP.
BTW: Choices A and B might cause some confusion since (LLQ) "The Low Latency Queueing feature brings strict priority queueing to Class-Based Weighted Fair Queueing (CBWFQ).".
