Is it possible to provide the QoS trust state/config dynamically to a switch port ? More particularly depending on the authentication of a device by NAC process and ISE 2.3.
For example :
- if device is authenticated then provide trust dscp
- if device is unauthenticated then port must be in untrust and dscp reset to 0.
If this particular example is not supported is there any other mean to make the trust state dynamic ?
Thanks in advance
