12-03-2006 08:10 AM - edited 03-03-2019 02:54 PM
hi all,
i am monitoring a network and i have a querry for what i need a solution. i want to know that how do i make sure that bandwidth utilization on gigabit port of my cisco 7206 is overutilized or underutilized.
i will be very much grateful to you
Nitin Mankar
12-03-2006 08:43 AM
Hi Nitin,
You have to consistently monitor the bandwidth utilization of the interface and see how much traffic it is processing. You have to set the parameter or business requirement that will underline the question of overutilization or underutilization. Every network is different and every business requirement is also diff to say that what would be over/under utilization in your scenario.
You can also use some tools to monitor the bandwidth utilization of the router interface like
Prtg: WWW.PRTG.COM
Mrtg: WWW.MRTG.com
Solar Winds
HTH, Please rate if it does.
-amit singh
12-04-2006 07:25 AM
hi amit,
thanks for the help. hope you all will help me out in future\
Nitin
