Query on BGP keep alive & Hold timers
fortis123
Hi all,
Simple yet would like to know..
If I setup bgp timers as 20 (keepalive) 60 (Holddown)
After how many keepalive misses the bgp peer declared to be down..? (one keep alive -20 or 3keep alives -60)..?
TIA
MS
Edison Ortiz
After 3 misses.
__
Edison.
Thank you Edison. I may be wrong here but from Cisco documentation...
"BGP uses certain timers to control periodic activities such as the sending of keepalive messages, and the interval after not receiving a keepalive message after which the Cisco IOS software declares a peer dead. By default, the keepalive timer is 60 seconds, and the holdtime timer is 180 seconds."
"and the interval after not receiving a keepalive message after which the Cisco IOS software declares a peer dead."
Iam kind of confused with "after not receiving a keepalive message".
Thank you
MS
Under normal conditions, the BGP speaking router will expect to send and receive hello/keepalive packets every 60 seconds.
However, it can miss one or two keepalive messages and the remote peer(s) can still consider the neighbor to be up.
After 3 missed keepalive messages, the peer(s) consider the neighbor to be dead hence the BGP peering is broken.
HTH,
__
Edison.
