Question about BSR for Anycast RP
gongya001
BSR-RP.JPGWhen RP are available on both Multicast domains, they work as expected.
RP-1#show ip mroute | b \(
(*, 239.100.100.100), 14:43:09/00:03:11, RP 100.100.100.100, flags: S
  Incoming interface: Null, RPF nbr 0.0.0.0
  Outgoing interface list:
    Ethernet0/1, Forward/Sparse, 14:43:09/00:03:11
(*, 239.5.5.5), 14:44:18/00:02:43, RP 100.100.100.100, flags: S
    Ethernet0/0, Forward/Sparse, 14:44:18/00:02:43
(*, 224.0.1.40), 14:46:36/00:02:17, RP 0.0.0.0, flags: DCL
    Loopback0, Forward/Sparse, 14:46:36/00:02:17
After some sending some pings, I got the following
R4#show ip pim rp
Group: 239.100.100.100, RP: 100.100.100.100, v2, uptime 02:07:08, expires 00:01:59
Group: 239.6.6.6, RP: 100.100.100.100, v2, uptime 02:07:08, expires 00:01:59
RP-2#show ip mroute | b \(
(*, 239.100.100.100), 16:17:32/00:02:50, RP 100.100.100.100, flags: SJC
    Ethernet0/0, Forward/Sparse, 02:07:33/00:02:50
(*, 239.6.6.6), 02:07:33/00:02:42, RP 100.100.100.100, flags: S
    Ethernet0/1, Forward/Sparse, 02:07:33/00:02:42
(4.4.4.4, 239.6.6.6), 00:00:54/00:02:05, flags: A
  Incoming interface: Ethernet0/0, RPF nbr 172.16.1.4
    Ethernet0/1, Forward/Sparse, 00:00:54/00:02:42
(172.16.1.4, 239.6.6.6), 00:00:54/00:02:05, flags: TA
(*, 224.0.1.40), 04:32:40/00:02:20, RP 0.0.0.0, flags: DPL
  Outgoing interface list: Null
Then I shutdown lo100 on R2,  I got the following on R1
(*, 239.100.100.100), 14:47:45/00:03:21, RP 100.100.100.100, flags: S
    Ethernet0/2, Forward/Sparse, 00:00:10/00:03:21
    Ethernet0/1, Forward/Sparse, 14:47:45/00:02:33
(*, 239.5.5.5), 14:48:53/00:03:04, RP 100.100.100.100, flags: S
    Ethernet0/0, Forward/Sparse, 14:48:53/00:03:04
(*, 239.6.6.6), 00:00:05/stopped, RP 100.100.100.100, flags: S
    Ethernet0/2, Forward/Sparse, 00:00:05/00:03:24
(172.16.1.4, 239.6.6.6), 00:00:05/00:02:54, flags: PMX
  Incoming interface: Ethernet0/2, RPF nbr 140.142.1.2
(4.4.4.4, 239.6.6.6), 00:00:05/00:02:54, flags: PMX
(*, 224.0.1.40), 14:51:11/00:02:42, RP 0.0.0.0, flags: DCL
    Loopback0, Forward/Sparse, 14:51:11/00:02:42
Seems that mcast route failed over to R1 from R2. I still can ping 239.6.6.6 from R4
R4#ping 239.6.6.6
Sending 1, 100-byte ICMP Echos to 239.6.6.6, timeout is 2 seconds:
Reply to request 0 from 6.6.6.6, 23 ms
Reply to request 0 from 6.6.6.6, 50 ms
Some time later, R4 has no more rp map, and R1 does not have  (*,G) from domain 65002.
(*, 239.100.100.100), 14:55:49/00:03:20, RP 100.100.100.100, flags: S
    Ethernet0/1, Forward/Sparse, 14:55:49/00:03:20
(*, 239.5.5.5), 14:56:58/00:02:51, RP 100.100.100.100, flags: S
    Ethernet0/0, Forward/Sparse, 14:56:58/00:02:51
(*, 224.0.1.40), 14:59:16/00:02:33, RP 0.0.0.0, flags: DCL
    Loopback0, Forward/Sparse, 14:59:16/00:02:33
What have I missed here ?
thanks !!
I have the exact same setup as you have. The 'ip pim bsr-border' command filters out the PIM message type that contains the RP information. The multicast information continues to work, but no RP information is shared. That is why after the expiration timer expires, R4 has no RP mapping.
--> After RP mapping expired, the traffic to multicast group was successful.
So you are saying you can ping 239.6.6.6 from R4 with no RP mapping ? It doesn't work in my lab...
8 Replies 8
is this a GNS3 project ? If so, post the gns3 file...
Hostname R3
ip multicast-routing
interface Loopback0
 ip address 3.3.3.3 255.255.255.255
 ip pim sparse-mode
 ip ospf 10 area 10
 ip igmp join-group 239.100.100.100
interface Ethernet0/1
 ip address 10.10.1.3 255.255.255.240
 ip pim sparse-mode
router ospf 10
 router-id 3.3.3.3
 network 10.10.0.0 0.0.255.255 area 10
Hostname R5
interface Loopback0
 ip address 5.5.5.5 255.255.255.255
 ip ospf 10 area 10
 ip pim sparse-mode
 ip igmp join-group 239.5.5.5
interface Ethernet0/0
 ip address 10.10.2.5 255.255.255.240
 ip pim sparse-mode
router ospf 10
 router-id 5.5.5.5
Hostname RP-1
interface Loopback0
 ip address 1.1.1.1 255.255.255.255
 ip ospf 10 area 10
 ip pim sparse-mode
 ip address 10.10.2.1 255.255.255.240
 ip pim sparse-mode
 ip address 10.10.1.1 255.255.255.240
 ip pim sparse-mode
interface Ethernet0/2
 ip address 140.142.1.1 255.255.255.240
 ip pim sparse-mode
 ip pim bsr-border
router ospf 10
 router-id 1.1.1.1
 redistribute bgp 65001 subnets
router bgp 65001
 bgp log-neighbor-changes
 no bgp default ipv4-unicast
 neighbor 140.142.1.2 remote-as 65002
 address-family ipv4
  redistribute ospf 10
  neighbor 140.142.1.2 activate
  network 100.100.100.100 mask 255.255.255.255
 exit-address-family
interface Loopback100
 ip address 100.100.100.100 255.255.255.255
 ip pim sparse-mode
ip pim rp-candidate Loopback100
ip pim bsr Loopback100 0 100
ip msdp peer 2.2.2.2 connect-source lo0 remote-as 65002
ip msdp originator-id lo0
Hostname RP-2
interface Loopback0
 ip address 2.2.2.2 255.255.255.255
 ip pim sparse-mode
 ip ospf 10 area 10
 ip address 172.16.1.2 255.255.255.240
 ip pim sparse-mode
 ip address 172.16.2.2 255.255.255.240
 ip pim sparse-mode
 ip address 140.142.1.2 255.255.255.240
 ip pim sparse-mode
 ip pim bsr-border
router ospf 10
 router-id 2.2.2.2
 redistribute bgp 65002 subnets
 network 172.16.0.0 0.0.255.255 area 10
router bgp 65002
 neighbor 140.142.1.1 remote-as 65001
 address-family ipv4
  neighbor 140.142.1.1 activate
 exit-address-family
 ip pim sparse-mode
ip msdp peer 1.1.1.1 connect-source lo0 remote-as 65001
Hostname R4
interface Loopback0
 ip address 4.4.4.4 255.255.255.255
 ip pim sparse-mode
 ip ospf 10 area 10
 ip address 172.16.1.4 255.255.255.240
 ip pim sparse-mode
router ospf 10
 router-id 4.4.4.4
Hostname R6
interface Loopback0
 ip address 6.6.6.6 255.255.255.255
 ip ospf 10 area 10
 ip pim sparse-mode
 ip igmp join-group 239.6.6.6
 ip address 172.16.2.6 255.255.255.240
 ip pim sparse-mode
router ospf 10
 router-id 6.6.6.6
gongya001
seems bsr-border cause that behavior.
I like to use bsr-border to prevent multicast domains from interraction unless the RP in one domain fails.  Is it possible ?
thanks !!
as far as I can tell, the BSR failover, in your case,  only works when there are no border interfaces. When you remove 'ip pim bsr-border' from both RP-1 and RP-2, the failover will work. The 'while' it takes for R4 to lose it's RP mappings is just the expiration timer expiring...
If you configure another BSR candidate either on R3/R5 or R4/R6, respectively, you can use the borders and still achieve failover...
thanks for taking a look at it.
1. After I failed over by shutting down lo100 on R2, all the source trees went to R1. But the newly registered group did not register to R1.
2. After RP mapping expired, the traffic to multicast group was successful.
So I guess my lab is not appropriate for test Anycast RP concept. As I tried to achieve Anycast RP between two different multicast domain.
I will try to see whether static RP works.
thanks !
I double checked with RP map expiration, no traffic was successful. sorry about that.
After I removed bsr-border, anycast RP worked as expected.
My lab comes from
From <http://resources.intenseschool.com/gns3-lab-basic-msdp/>.
For anycast section, I just like to try BSR instead of static RP.
