Question regearding PBR on L2L ASA
Melinbonian
Hello
i was wondering if it's possible to use PBR on a site to site vpn between 2 asas, using static routes . Obviously, with version after 9.4.1 that supports PBR.
Basically, you can policy-route traffic for the VPN. What exactly do you want to do?
Not sure what you want to do but if pbr and crypto are applied to same
interface, pbr is applied first and should match tunnel ips.
Other than that its straight forward pbr and not related to crypto
