03-31-2010 02:58 PM - edited 03-04-2019 08:00 AM
I think I heard this before but I can't find the answer:
Imagine you have route-maps, prefix-lists etc filtering a given advertised BGP route.
Then you want to analyze how the advertised routes to a neighbor would look like without the effect of the aforementioned prefix-lists, route-maps, etc.
Is there any command to accomplish that?
To my understanding 'advertised-routes' should list the output of the actual advertised routes to a neighbor including filters (such as prefix-lists, route-maps).
R2#show ip bgp neig 10.2.2.47 ?
advertised-routes Display the routes advertised to a BGP neighbor
dampened-routes Display the dampened routes received from neighbor (eBGP
peers only)
flap-statistics Display flap statistics of the routes learned from
neighbor (eBGP peers only)
paths Display AS paths learned from neighbor
received Display information received from a BGP neighbor
received-routes Display the received routes from neighbor
routes Display routes learned from neighbor
| Output modifiers
<cr>
Solved! Go to Solution.
03-31-2010 03:24 PM
Hello Marlon,
sh ip bgp
if no filter is applied all valid BGP routes not learned by that neighbor would be advertised to it
so if x.x.x.x is the neighbor
sh ip bgp | exclude x.x.x.x
should give you a good approximation of you would send to x.x.x.x without any filter applied: all the local RIB
well actually only >* best paths are sent out
soa regular expression would be needed
sh ip bgp | include *>
Hope to help
Giuseppe
03-31-2010 03:24 PM
Hello Marlon,
sh ip bgp
Hope to help
Giuseppe
