10-31-2013 01:22 AM - edited 03-04-2019 09:28 PM
Today we decided to give release 3.10.1S a try on our least loaded ASR1002 (which we use for PPPoE). The device has two GbE interfaces in a port-channel (per-vlan manual balancing) and the first thing I noticed after the reload was that one of those interfaces would not increment output traffic - this one got solved by taking it out of the port-channel and adding it back.
The minor thing is that "show version" says that <<System image file is "bootflash:asr1000rp1-advipservicesk9.03.10.01.S.153-3.S1-ext.bi">> - I guess the string got one character too long for the allocated size .
And two more questions regarding 3.10S series:
- what do "ext" and "noli" stand for in image names?
- when will the Release Notes be updated for 3.10.1S?
Thank you.
09-13-2016 07:22 AM
Actually, I'm having this doubt. Found nothing in Internet and documentation.
What's the difference between
asr1001x-universalk9.03.13.06.S.154-3.S6-ext.SPA.bin
asr1001x-universalk9_noli.03.13.06.S.154-3.S6-ext.SPA.bin
Christian
09-13-2016 07:26 AM
I think "noli" means "without lawful intercept"...
