queue time doesnot match
maya davidson
I have a network topology as below:
R2 - R3 - R4
         R1
My bandwidth are 100Mbps, queue sizes are 1000 packets, fifo
and I am sending 12500 frame/second and 1000byte each frame ,
from R2- R3
and another one R1-R3
Loss is around 1.96% for both flows, but the delay is 0.007s for the first flow and 0.4s for the second flow,
which in theory i can calculate the queuing time as below,
queue sizes / (bandwidth / packetsize * = 0.08s
the R2 and R3 are from 9200 cisco and R1 c1111
I don't know where I am getting wrong that with the same configs i am getting delays which none of them are correct.
Thanks for your help in advance
30 Replies 30
CaroleMay
The discrepancies in delay and packet loss in your network setup can be attributed to several factors:
  1. Flow Calculations: You're sending 12,500 frames per second, each 1,000 bytes, which saturates the 100 Mbps link between R2 and R3, leading to potential queuing delays.
  2. Queue Size and Delay: The calculated queuing delay of 0.08 seconds (80 ms) aligns with your theory, but the 0.4 seconds delay for the R1-R3 flow suggests R1 may be a bottleneck.
  3. Router Performance: The Cisco C1111 router (R1) may have lower processing capabilities compared to the Cisco 9200 series (R2 and R3), causing increased queuing and processing delays.
  4. Packet Loss: The 1.96% packet loss indicates that incoming traffic may exceed R1's processing capacity, leading to dropped packets.
Recommendations:
  • Check R1 Configuration: Optimize R1's settings and consider increasing buffer sizes or implementing QoS to prioritize traffic.
  • Monitor Resource Utilization: Check CPU and memory usage on R1 to identify potential overload issues.
By addressing these factors, you can improve the performance and reduce delays and packet loss in your network.
