"WR" can't save the running-config
yuanchenxin
There are some troubles in my 7206 vxr . The process of this problem below.
LOG:
Self decompressing the image : ########################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################## [OK]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, 7200 Software (C7200P-ADVIPSERVICESK9-M), Version 12.4(22)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 10-Oct-08 11:19 by prod_rel_team
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Installed image archive
Cisco 7206VXR (NPE-G2) processor (revision A) with 917504K/65536K bytes of memory.
Processor board ID 37106353
MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.2
6 slot VXR midplane, Version 2.11
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 0 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
1 FastEthernet interface
3 Gigabit Ethernet interfaces
2045K bytes of NVRAM.
253008K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
65536K bytes of Flash internal SIMM (Sector size 512K).
         --- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]: n
Press RETURN to get started!
*Jan  1 00:00:06.539: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Jan  1 00:00:06.539: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to up
*Jan  1 00:00:06.539: %LINK-3-UPDOWN: Interface GigabitEthernet0/2, changed state to down
*Jan  1 00:00:06.539: %LINK-3-UPDOWN: Interface GigabitEthernet0/3, changed state to down
*Jan  1 00:00:06.539: %LINK-3-UPDOWN: Interface FastEthernet0/2, changed state to down
*Jan  1 00:00:07.219: %LINEPROTO-5-UPDOWN: Line protocol on Interface SSLVPN-VIF0, changed state to up
*Jan  1 00:00:07.539: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
*Jan  1 00:00:07.539: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/2, changed state to down
*Jan  1 00:00:07.539: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/3, changed state to down
*Jan  1 00:00:07.539: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/2, changed state to down
*Jan  1 00:00:57.367: %LINK-5-CHANGED: Interface GigabitEthernet0/1, changed state to administratively down
*Jan  1 00:00:57.391: %LINK-5-CHANGED: Interface FastEthernet0/2, changed state to administratively down
*Jan  1 00:00:57.407: %LINK-5-CHANGED: Interface GigabitEthernet0/2, changed state to administratively down
*Jan  1 00:00:57.435: %LINK-5-CHANGED: Interface GigabitEthernet0/3, changed state to administratively down
*Jan  1 00:00:58.367: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down
*Jan  1 00:01:04.003: %SYS-5-RESTART: System restarted --
*Jan  1 00:01:04.007: %ENTITY_ALARM-6-INFO: ASSERT CRITICAL SFP Slot 0/1 SFP is missing
*Jan  1 00:01:04.007: %ENTITY_ALARM-6-INFO: ASSERT INFO Gi0/1 Physical Port Administ
*Jan  1 00:01:04.007: %ENTITY_ALARM-6-INFO: ASSERT CRITICAL SFP Slot 0/2 SFP is missing
*Jan  1 00:01:04.007: %ENTITY_ALARM-6-INFO: ASSERT INFO Gi0/2 Physical Port Administrative State Down
*Jan  1 00:01:04.007: %ENTITY_ALARM-6-INFO: ASSERT CRITICAL SFP Slot 0/3 SFP is missing
*Jan  1 00:01:04.007: %ENTITY_ALARM-6-INFO: ASSERT INFO Gi0/3 Physical Port Administrative State Down
*Jan  1 00:01:04.007: %ENTITY_ALARM-6-INFO: ASSERT INFO Fa0/2 Physical Port Administrative State Down
*Jan  1 00:01:04.783: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Jan  1 00:01:04.783: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Jan  1 00:01:04.835: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing a cold start
Router>
Router>en
Router#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#hos
Router(config)#hostname r1
r1(config)#end
r1#wr
NV: Invalid Magic(0x824A) found in NVRAM.....Erase of configuration files recommended
startup-config file open failed (Not enough space)
r1#
*Jan  1 00:01:20.599: %SYS-5-CONFIG_I: Configured from console by console
r1#
r1#
r1#
r1#sh star
r1#sh startup-config
startup-config is not present
r1#dir nvram:
Directory of nvram:/
2044  -rw-           0                    <no date>  startup-config
2045  ----           0                    <no date>  private-config
2046  -rw-           0                    <no date>  underlying-config
    1  ----          49                    <no date>  persistent-data
2095096 bytes total (2094020 bytes free)
I nend some help.
milan.kulik
Level 10
Level 10
as recommended by the error mesage have you tried to delete the current startup-config file by
delete nvram:startup-config
command?
There's also an IOS bug
CSCek26044
NV: Invalid Magic found in NVRAM.....Erase of configuration files recommended
Conditions: This symptom is observed on a Cisco platform that runs Cisco IOS interim Release 12.4(6.7) or interim Release 12.4(6.6)T and affects the following platforms: Cisco 2811, Cisco 2821, Cisco 2851, Cisco 3825, Cisco 3845, and a BCM-based Cisco AS5400.
Workaround: There is no workaround.
Possibly similar bug in your IOS? And an IOS upgrade might help?
HTH,
Milan
Message was edited by: MILAN KULIK
milan.kulik
Level 10
Level 10
command?
CSCek26044
HTH,
Milan
Tks for your answer. I'll try it letter.
