Radius Server Dead
WMA Hell
I get these periodically during the day on the router syslog.
Feb 16 19:33:22.817 EDT: %RADIUS-4-RADIUS_DEAD: RADIUS server x.x.x.x:1645,1646 is not responding.
Feb 16 19:33:22.817 EDT: %RADIUS-4-RADIUS_ALIVE: RADIUS server x.x.x.x:1645,1646 is being marked alive.
We have radius on a Windows Network Policy Server on two servers. CPU/Memory/Bandwidth are never more than 50% utilization.
Router#sh run | inc radius
ip radius source-interface GigabitEthernet0/0/0.x
radius server Salt
radius server Pepper
What does this tell me? How do I fix it?
Sorry I was busy last days
Now the server is detect life dead
if we merge two issue together we get same result there is interface congestion that drop control/mgmt traffic
show policy-map interface <<- share this if you can
MHM
Mark Elsen
  - Check if the router has a solid network  connection to the radius server.
     + Check the radius server's logs when that happens .
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
MHM
Team
As it turns out that second Radius server was decommissioned 6 months ago. I need to rebuilt it using the same line in the configuration and the IP.
Currently they have a Windows Radius solution. Should I just build a second Windows Radius server or leverage ISE for this?
How do you integrate two different Radius server platforms?
Matt
          >...Should I just build a second Windows Radius server or leverage ISE for this?
  - You may for instance compare performance rates as mentioned in https://www.cisco.com/c/en/us/td/docs/security/ise/performance_and_scalability/b_ise_perf_and_scale.html#reference_dfk_mjh_m5b   with other radius servers
       >...How do you integrate two different Radius server platforms?
   - Try to keep them the same ; the authenticating policies will become more  complicated for instance and
      or playing with load balance or timeout settings will loose it's efficiency or disappear ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
