Random websites doesn't work
Greatings,
I have an
awkward
behaviour of a
CISCO 1921/K9
configured with WAN on a
PPPoE
Connection. Some websites, a few, does not load at all, but subdomains of the above not working website, DOES load (slower, but they do).
How come? I  have no clue why. A colegue spoked with the ISP and said that sometime CISCO devs need to be configured with a higher cache!
Now, what kind of cache is it about?
here is my runnning conf:
gw01#sh run
Building configuration...
Current configuration : 5735 bytes
! No configuration change since last restart
version 15.1
hostname gw01
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 192.168.3.1
ip dhcp pool DSL_DHCP
network 192.168.3.0 255.255.255.0
default-router 192.168.3.1
dns-server 213.154.124.1 193.231.252.1
ip domain name mydomain.local
ip name-server 213.154.124.1
ip name-server 193.231.252.1
crypto pki trustpoint TP-self-signed-3660350312
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3660350312
revocation-check none
rsakeypair TP-self-signed-3660350312
crypto pki certificate chain TP-self-signed-3660350312
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33363630 33353033 3132301E 170D3133 30383236 30373537
  31375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 36363033
  35303331 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100D1D6 3320C0F8 3B498654 4C395FAE C5E6C8B7 DD8602CA 5CB77F99 0DDDCBEF
  CE7D529E 607CFD6F 835A76C2 FDF177FB FFFCEFFF 5724F7CF 41AD3734 18E47CC3
  EFB3FE1B 0C94FD90 21482754 4A9EC532 8526F4C9 2BAF9ECD 7000D8B0 76722517
  16F5B991 1FEC6B74 A631FA63 877DB3C8 F86275CA C0B01EBD DC031A84 CD4F90DD
  35430203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14F1C5F3 A0AC712A 688AAA47 F97E5BB4 9141C410 C4301D06
  03551D0E 04160414 F1C5F3A0 AC712A68 8AAA47F9 7E5BB491 41C410C4 300D0609
  2A864886 F70D0101 05050003 8181000E 248E5FA3 0374D89D FBBCDFE3 D26A993E
  5659E560 F0DF6B5D CD23761F 8D9B6784 9F204D80 B1AC2A05 E4F72927 868E829C
  06B1CF3D 16898DC9 348A4DD9 18A4D307 F109E4C0 D91BC160 C84B1F6A 5004B6C0
  18E64577 40BCAF80 69184398 1AFD5DEE FE889E4B 7190B4E9 AA888195 79A8D450
  A9228CD9 EACBA6A0 EDDA85AF 40AC62
        quit
license udi pid CISCO1921/K9 sn FCZ163021Q6
username master privilege 15 secret 4 H3rE'l1_6e_+h3_p@5sw08D        c
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description DSL INT$ES_WAN$
no ip address
ip flow ingress
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface GigabitEthernet0/1
ip address 192.168.3.1 255.255.255.0
ip flow ingress
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
ppp authentication chap pap callin
ppp chap hostname CRPTR208065987
ppp chap password 0 208065987
ppp pap sent-username CRPTR208065987 password 0 PASSWORD
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list DSL_ACC interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list extended DSL_ACC
remark CCP_ACL Category=18
permit ip 192.168.3.0 0.0.0.255 any
control-plane
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
Any help will be much apreciated! Thank you.
Mike Williams
Level 5
Level 5
For
PPPoE
you need to adjust the TCP maximum segment size. Under the LAN interface, enter the command
ip tcp adjust-mss 1452
Standard practice is to configure the mss as 40 bytes less than the MTU for Ethernet overhead.
Mike
Sent from Cisco Technical Support Android App
17 Replies 17
Seb Rupik
There is nothing unusual about your config that would single out particular websites.
Are you running
IPv6
on your network? I have seen some cases where a browser will attempt an
IPv6
connection and just hang there. It is possible that the
sub-sites
do not have
AAAA DNS
records so your browser connects using
IPv4
Are you able to run a
packet capture
on your machine, filtering on destination address and port 80, to see what traffic is being generated.
What are the URLs of these websites; both the working and slow ones?
Can I also suggest you enable
service password-encryption
on your router.
cheers,
Seb.
Thank you for your replay, Seb Rupik.
We run IP v4 in the LAN, no IP v6.
the sites that are not working:
www.microsoft.com, adobe.com, behance.com and some more.
this is not working
hotnews.ro, but forum.hotnews.ro
it does load.
Strange thing is that it hangs after the browser get a Status 200 respons from the remote web server on every website that doesn't work.
Websites that works:
google.com, yahoo.com, ultrashock.com, youtube.com.
I'm sorry, I can't install any packet sniffer on this machine.
Thank you.
Has your web browser been configured to use a proxy?
If you have a second web browser installed to you get the same result?
Do you have a webcache server installed on the network?
I have two browsers, IE and Fierfox, both hangs on getting the result form destination web server at the first GET.
Other destination websites hangs after (in Firefox) the browser took some resources, but displays none. But I can see its source.
No proxy config-ed.
Webcache server, not that I know about.
No too long ago I experienced the same problem and it turned out to be my isp DNS, they replace who knows what but it took them 15 days to have our transmission back to normal.... while waiting for a fix we used google's
dns 8.8.8.8
and we were able to access the web again......
same issue , I can't install any packet sniffer on my machine.
Ernesto - Certified Cisco Specialist.
Mike Williams
Level 5
Level 5
For
PPPoE
Mike
Thank you Mike Williams and all of you guys.
This command has did the job.
(But for my own culture, can you please explain to me what does mss means?)
Edit:
I got it.
Thank you again.
I'm glad you got it working.
Mike
If your provider supports mini jumbo frames
(RFC4638)
you should be able to dispense with
on the LAN interface.
This is what I have configured on my
C891F
router and the
 ppp session info (show ppp interface virtual-access 3)
interface GigabitEthernet8
 mtu 1508
 no ip address
 duplex auto
 speed auto
 pppoe-client ppp-max-payload 1500
 no cdp enable
Vi3 LCP: [Open]
Our Negotiated Options
Vi3 LCP: MagicNumber 0x808B977A (0x0506808B977A)
Peer's Negotiated Options
Vi3 LCP: MRU 1500 (0x010405DC)
Vi3 LCP: MagicNumber 0x5BCC96D0 (0x05065BCC96D0)
I had same problem and adjusting
tcp-mss
helped!! Thanks a ton
Thankyou sir this fixed my issue which I was tearing my hair out over
Is this happened after using the VPN or before? because I'm having an issue in a website that is not opening no matter what I do. It says due to security reason return back to safety.
what is the URL of that website ?
