Rate Limit external application
marcin.adamus
Hello
I need to set policy limit rating for ftp but not for computers in network but for client thats connecting from the world.
I create rate-limit policy but doesn't work, maybe someone have example.
Varun Uniyal
can you post your config please
interface FastEthernet0/0
description WAN
ip address xx.xx.xx.xx
ip nat outside
ip virtual-reassembly
rate-limit output access-group 111 5120000 16000 24000 conform-action transmit exceed-action drop
duplex auto
speed auto
crypto map vpn
access-list 111 permit tcp any any eq www
access-list 111 permit tcp any eq www any
in this config file i try to test on http
In this config file i try to test on http
The target is to achieve that in pool is 2Mbits and is divided by number of connections where minimum transfer rate is 64 kb
