Rate limit on a IPSEc Tunnel
asoka
HI, Is it possible to limit traffic in a IPSec Point tto Point tunnel, I have 4Mbps link and I want to limit 2Mbps to VPN tunnel and other 2Mbps for general Internet traffic, can it be done pls give me some examples.
2 Accepted Solutions
Eugene Khabarov
Level 7
Level 7
Something like this:
Interface
rate-limit input access-group 100 2000000 2400 2400 conform-action transmit exceed-action drop
rate-limit output access-group 200 2000000 2400 2400 conform-action transmit exceed-action drop
ip access-list extended 100
permit esp host host
permit ahp host host
ip access-list extended 200
I think that rate-limit (policing) will have an adverse effect as it do not buffer.
You may want to look into traffic shaping with modular qos cli instead.
9 Replies 9
Jon Marshall
asoka@people.net.au
Which device and IOS ?
Jon
This is a 1760 router, IOS 12.4, running
c1700-advipservicesk9-mz.124-13b.bin
Eugene Khabarov
Level 7
Level 7
Interface
Thanks for your input, Few questions though,
IN this method you need to apply in both direction isnt it, but I feel like applying that to two different interfaces,
rate-limit input to inside interface
rate-limit output to outside interface
Otherwise packet enter the router and then drop at inside interface isn't it
And, in this method I can rate limit the, let say, Internet bound traffic to 3Mbps and then automaticaly I have reserved 1Mbps to VPN tunnel traffic, is it correct ??
And if you could give me some guidence in that direction pls
Hi, I just realised that will be bit difficult with NATing , isn't it
How can you differenciate traffic before NATing interface
Or what is the best method to limit traffic to and from Internet to users,
Nat traffic have private address that you can identify with a three lines ACL.
NAT also provides a virtual interface of optional use.
Alls these things are easier for a certified professional that I would recommend to engage for best results.
Yes, it is good idea. This should slightly reduce the CPU load
This is correct if your ISP guarantees you 4 Mbps bandwidth. For the best result you can use shapers instead of rate-limit.
http://www.cisco.com/en/US/docs/ios/12_0/qos/configuration/guide/qcgts.html
