rate-limit question
fallonem82
Is this correct?
A 5Mb link burstable to 10Mb. The following command:
rate-limit output 5000000 2500000 5000000 conform-action transmit exceed-action drop
would allow a 5Mb link with 2.5Mb bursts (=1.5 seconds) upto 5Mb or 10Mb total
guruprasadr
Level 7
Level 7
HI, [Pls Rate if HELPS]
bps
>>Average rate in bits per second. The value must be in increments of 8 kbps.
burst-normal
>>Normal burst size in bytes. The minimum value is bps divided by 2000.
burst-max
>>Excess burst size in bytes.
The above is the logic in QOS rate-limit calculation.
Do Rate if HELPS
Best Regards,
Guru Prasad R
Lets try this again and I'll use proper bit numbering instead of rounding
rate-limit output 5242880 2622 655360 conform-action transmit exceed-action drop
this command will allow a 5Mb connection with a normal-burst of 2622Bytes (5242880/2000) upto a max burst of 5Mb (5242880/8) effectively allowing a 5Mb link to burst to a total of 10Mb
Is this right or am I WAY off?
"2000" is the default value for normal-burst and max-burst and do follow the same if the link capacity is only 5 Mb.
Consider the Link is 10 Mb where internet traffic is limited to 5 Mb means:
rate-limit input access-group 100 5000000 1000000 1000000 conform-action transmit exceed-action drop
In the above Eg:
>>5 Mb of normal traffic
>>1 Mb of Normal Burst
>> 1 Mb of Max Burst
Hope this is Informative
PLS RATE if HELPS
Best Regards,
Guru Prasad R
