Rate-limit
mukendi
From the statement below,the normal and max burst(2000 2000),are these parameters set up arbitrary or by calculation?Please advise
rate-limit input access-group 120 360000 2000 2000 conform-action
transmit exceed-action drop
5 Replies 5
rkhalil
We calculate as follows...as specifications of Cisco.
Bits per second = MBits*1000000
Normal burst bytes = (Bits per second)/8*1,5
Maximum burst bytes = (Normal burst bytes)*2
Raul
(please rate helpful posts)
Hi Raul,
You are right,your answer can be verified by the statement below,keep it up!
rate-limit output 128000 24000 48000 conform-action transmit exceed-action drop
So, if we have 155 Mbps, then it will be:
Bits per second = MBits*1000000 = 155000000
Normal burst bytes = (Bits per second)/8*1,5 = 29062500
Maximum burst bytes = (Normal burst bytes)*2 = 58125000
e.g:
interface gigabitEthernet 0/3
rate-limit input 155000000 29062500 58125000 conform-action transmit exceed-action drop
rate-limit output 155000000 29062500 58125000 conform-action transmit exceed-action drop
-zamri-
Yes that's is ok.
Thank you. :)
-zamri-
