RE: Addressing Scheme
scott_mchale
Guys,
Please help!!!
I have been asked to design an addressing scheme that will support 930 users. The design must allow for 30% growth, so if my calculations are correct this would take us to 1209.
Glasgow Office:
50 Warehouse Staff
150 Customer services
100 Finance
Total 300 (still to add 30%)
Birmingham office
75 Warehouse staff
100 Customer services
75 Finance
Total: 250 (still to add 30%)
Five regional sites
Aberdeen 20 staff
Newcastle 40 staff
Liverpool 20
Bristol 20
london 30 staff
Total 250 (still to add 30%
each region also has a number (up to 5) of smaller branch sites with less than 10 staff each.
The company leases a range of class C networks of public IP addresses from its main ISP.
I am trying to find a suitable Network address that will support this.
Many thanks
Scott
19 Replies 19
Danilo Dy
Did they give you a range of IP Address to use and subnet?
If not, this means you have a free hand on the ip address assignment. Use some coding in the second and third octet to identify the site and department.
Dandy
Hi Dandy,
No range of IP addresses or subnets given.
Not sure what you mean by "coding in the second and third octet to identify the site and department."
Seem to be hitting a wall everytime when using VLSM.
what Network Address should I use.
Scott
Hi Dandy
Cant see your reply, even though I received an email to advise one had been posted.
Scott
Hi Dandy
Scott
This means you have a free hand on the ip address range, you don't have to worry about giving the exact requirement. For example, you can give each site/department a /24 (or 255.255.255.0 network mask).
Coding example is the current International Telephone Coding Number which includes country code and area code. For example, if you use 10/8 (or 10.0.0.0/255.0.0.0).
GLASGOW: aaa
- Warehouse Staff: 0 = 10.aaa.0.0/24
- Customer Services: 1 = 10.aaa.1.0/24
- Finance: 2 = 10.aaa.2.0/24
BIRMINGHAM: bbb
- Warehouse Staff: 0 = 10.bbb.0.0/24
- Customer Services: 1 = 10.bbb.1.0/24
- Finance: 2 = 10.bbb.2.0/24
ABERDEEN: ccc/ddd
10.ccc.ddd.0/24
NEWCASTLE: eee/fff
10.eee.fff.0/24
LIVERPOOL: ggg/hhh
10.ggg.hhh.0/24
BRISTOL: jjj/kkk
10.jjj.kkk.0/24
LONDON: mmm/nnn
10.mmm.nnn.0/24
You can replace the letters with either country code or area code. If the code is higher than the valid ip address, make some adjustment. When looking at the routing table, you will be able to easily identify where the route/s came from (and where to route it).
Take note that the above is only an example. It depends if you like the idea and if you really want to follow the requirement,
Dandy
Hi Dandy,
Thanks for your help...
To let you understand I am currently at the end of my Honours year at University, and although the above is helpful, I am afraid I am still a little confused. Is there an easier way to explain this.
Scott
Well, you didn't mentioned this earlier. It seems that this is one of your project or something for your studies?
I guess you have to follow the requirement. Let me work on something and get back to you :)
If you have the time Dandy, I can certainly send you the document.
Scott
Try this....
[EDIT] Glasgow Office: 10.1.0.0/22 = 10.1.0.0/24, 10.1.1.0/24, 10.1.2.0/24, and 10.1.3.0/24
- 50 Warehouse Staff (+30% = 65) = The closest subnet is 10.1.0.0/25 (maximum hosts is 126)
- 150 Customer services (+30% = 195) = The closest subnet is 10.1.1.0/24 (maximum hosts is 254)
[EDIT]- 100 Finance (+30% = 130) = The closest subnet is 10.1.2.0/24 (maximum hosts is 254)
Birmingham office: 10.2.0.0/23 = 10.2.0.0/24 and 10.2.1.0/24
- 75 Warehouse staff (+30% = 98) = The closest subnet is 10.2.0.0/25 (maximum hosts is 126)
- 100 Customer services (+30% = 130) = The closest subnet is 10.2.1.0/24 ( maximum hosts is 254)
- 75 Finance (+30% = 98) = The closest subnet is 10.2.0.128/25 (maximum hosts is 126)
Five regional sites
Aberdeen 20 staff (+30% = 26): The closest subnet is 10.3.0.0/27 (maximum hosts is 30)
Newcastle 40 staff (+30% = 52): The closest subnet is 10.3.0.128/26 (maximum hosts is 62)
Liverpool 20 staff (+30% = 26): The closest subnet is 10.3.0.32/27 (maximum hosts is 30)
Bristol 20 staff (+30% = 26): The closest subnet is 10.3.0.64/27 (maximum hosts is 30)
london 30 staff (+30% = 39): The closest subnet is 10.3.0.192/26 (maximum hosts is 62)
Other Senior NetPros may be able to advice a better combination :)
Dandy,
Thanks for your help, greatly appreciated.
Much clearer
Thanks again
Scott
Please check th update [EDIT], sry I was playing AAO :)
the answer you provided has been helpful
thank you
Hi Dandy,
Sorry to bother you again.
Subnetting for Glasgow does not work, it works if we dont allow for 30% growth with the finance department. Or maybe I am doing something wrong. Please advise.
Glasgow Office: 10.1.0.0/23 = 10.1.0.0/24 and 10.1.1.0/24
- 100 Finance (+30% = 130) = The closest subnet is 10.1.0.128/25 (maximum hosts is 126)
Yes, I noticed that, that's why I update the earlier post. Check the [EDIT] portion. Anyway, here it is
