RE: no pppoe-client command for vlan interface
weiherd79
refer the attached picture
I need the pppoe-client command apply on vlan interface but seen like no support
does anyone know ?
thanks
ai.solutions
I would have a look at your IOS version... I am running:
c180x-advipservicesk9-mz.124-15.T17.bin
(Yes its an 1801, different but I think you may require a "T" IOS.
ai.solutions
thanks ai.solutions after i use "T" IOS problem solved
