172
Beginner
received BGP routes not populating table
I have an ISR 4451 running ios 15.5(2)S1c.  It has a number of eBGP peers which have been working fine for ages.  Ive added a new BGP peer simply via
router bgp <my-as>
 bgp log-neighbor-changes
 neighbor 10.66.250.202 remote-as 12076
sh ip bgp summ shows the peering as good.
When i run "show ip bgp nei 10.66.250.202 received-routes" it correctly lists the advertisements i expect.
However "show ip route bgp" does not list these routes. What troubleshooting steps should i take to see why the received routes arent being loaded into the local table?
Everyone's tags (1)
3 REPLIES 3
Enthusiast
Re: received BGP routes not populating table
The command show ip bgp neighbour 10.66.250.202 received-routes shows you bgp prefixes from neighbor 10.66.250.202 before applying all filters. So, if you don't see prefixes in bgp table what you expect look at the inbound filters for neighbor 10.66.250.202
Everyone's tags (1)
VIP Mentor
do you have access to the eBGP peering configuration of the other side (the neighbor) ? Can you post that ?
VIP Advisor
Hello
As its been stated already seeing prefixes in the bgp table doesn't necessarily mean those routes will make into the routing table as by default only the best calculated route(s) to these prefixes are accepted by the router.
Can you post the output of the bpg table pertaining t those routes?
sh ip bgp
sh ip bgp | in xxxxx
kind regards
Paul
Please rate and mark posts accordingly if you have found any of the information provided useful.
It will hopefully assist others with similar issues in the future
Content for Community-Ad
July's Community Spotlight Awards
