Recommendations for equipment refresh
dmc3106cisco
The healthcare organization I work for has joined forces with the local hospital and plans to upgrade/refresh equipment in the near future.  Currently, our network and the hospital's networks work independently but will likely become 'one'.  Our organization has several sites with a 3750Catalyst at the main site and 2651XM's at the remotes performing routing duties. Metro-E links connect our offices. Otherwise, there are are many 3650 POE 10/100 switches for the access layer.  I believe the hospital has 5000 or 6000 series chassis supporting their network.  Future services, which our organization does not currently have, may include Cisco VOIP telephony.  I would appreciate insight anyone can provide recommendations for what type equipment would be a good fit for our organization to upgrade to.  If further details is needs, I will be glad to provide.  thanks -
Leo Laohoo
If you are only using the 3560 as a Layer 2 access switch then I'd be looking at the new 2960S family.
If you want to upgrade this then I'd consider waiting for a few more months for the new VS-Sup2T will be coming out.  Do NOT buy any blades "in anticipation" until the new supervisor blade comes out before August 2011.
Whaaaa?  No wireless?
