Recommended Static NAT Hardware
MikeDobbins8435
I am looking for a recommendation on what hardware supports static NAT of duplicate address with a minimum of 16 ports.
The situation is 6 to 14 OEM devices in a group, with IP address 192.168.0.11 to 192.168.0.25, that needs to be accessible to data collection.  And there are 4 to 16 groups of the same setup of devices. So each port of the network hardware needs to be connected to one group of devices. And each group mapped to 10.1.50.xxx.
balaji.bandi
You can have any Router ISR / ASR does this natting for you.
Router ===L2 Switch===Device with different VLAN connected
BB
Deepak Kumar
Go with ISR series router.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
