redistribute bgp into eigrp question
suelange
I am doing a simple lab exercise trying to redistribute bgp into eigrp. It is not working. The info I can find on internet such as troubleshooting flow charts says there are mainly 3 reasons: either no metrics, discontiguous nets, or the route is not in the table. Those are not the case but still I can not see the route in the eigrp topology table hence it can't pass that route over to the neighboring eigrp router. What are all the possible reasons why a route from bgp won't distribute into eigrp?
R1
R1#show run
Building configuration...
Current configuration : 1831 bytes
version 12.3
hostname R1
ip subnet-zero
ip cef
interface Loopback1
ip address 1.1.1.1 255.255.255.255
interface FastEthernet0/0
ip address 10.32.1.3 255.255.0.0
duplex auto
speed auto
interface Serial1/0
ip address 68.136.221.66 255.255.255.252
encapsulation frame-relay
serial restart-delay 0
no dce-terminal-timing-enable
frame-relay interface-dlci 221
router eigrp 32
redistribute bgp 1 metric 6144 100 255 1 1500
network 1.1.1.1 0.0.0.0
network 10.0.0.0
no auto-summary
router bgp 1
no synchronization
bgp log-neighbor-changes
network 10.32.0.0 mask 255.255.0.0
network 63.76.64.88 mask 255.255.255.248
neighbor 68.136.221.65 remote-as 1
neighbor 68.136.221.65 timers 12 36
no auto-summary
ip classless
Show Route:
Gateway of last resort is not set
68.0.0.0/30 is subnetted, 1 subnets
C 68.136.221.64 is directly connected, Serial1/0
1.0.0.0/32 is subnetted, 1 subnets
C 1.1.1.1 is directly connected, Loopback1
10.0.0.0/16 is subnetted, 2 subnets
B 10.1.0.0 [200/0] via 68.136.221.65, 00:02:47
C 10.32.0.0 is directly connected, FastEthernet0/0
R1#show ip eigrp top all
IP-EIGRP Topology Table for AS(32)/ID(1.1.1.1)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
r - reply Status, s - sia Status
P 1.1.1.1/32, 1 successors, FD is 128256, serno 2
via Connected, Loopback1
P 10.32.0.0/16, 1 successors, FD is 281600, serno 3
via Connected, FastEthernet0/0
cfolkerts
Which route or network are you trying to pass into EIGRP?
The route that should be going in there is the one learned via BGP which in this case is 10.1.0.0 255.255.0.0.
The 1.1.1.1 route, which is a loop back, is being passed over the the neighboring router via eigrp, so I know that the two routers are doing EIGRP correctly with each other. But the bgp route (10.1.0.0) is not ever being redirected into eigrp topology much less being passed across to the eigrp neighbor.
Sue
If I am reading the config correctly your BGP neighbor is in the same AS and so is an IBGP neighbor. By default routes learned by IBGP do not redistribute into an Interior routing protocol like EIGRP. So this is the cause of your problem.
You can use the command bgp redistribute-internal under the bgp process to change this behavior. It should allow the redistribution of the BGP routes into EIGRP.
Rick
Rick
Yep Yep Yep...that were it....
Thanks so much. I saw that command but know so little still about BGP that I couldn't imagine what bearing it had. The book I was reading indicated BGP is pretty much an external routing protocol. So...what makes it an "internal" version is if it has the same AS number as it's neighbor... Okay good to know that one for the test.
