redistribute bgp into eigrp
stephtchoko
Level 3
Level 3
Good day,
i want to redistribute bgp into eigrp,there is a special rule for it ??
If possible, please provide an example.
Best regards.
8 Replies 8
Kevin Dorrell
Level 10
Level 10
router eigrp as-number
  redistribute bgp bgp-as-number
  default-metric 1000 100 255 1 1500
Don't forget to configure the metric, otherwise it won't happen.
Kevin Dorrell
Luxembourg
I have done it, but the bpg isn't redistributed into eigrp .
There is topology
RTA connected to RTB via BGP and RTB connected to RTC via EIGRP.
RTA:
interface Loopback0
ip address 195.24.15.1 255.255.255.0
interface Loopback1
ip address 195.24.14.1 255.255.255.0
interface Ethernet0/0
ip address 196.202.232.63 255.255.255.128
full-duplex
interface Ethernet0/1
full-duplex
router bgp 65512
no synchronization
bgp log-neighbor-changes
network 195.24.14.0
network 196.202.232.0
neighbor 196.202.232.65 remote-as 65512
RTB
ip address 196.202.232.65 255.255.255.128
no ip directed-broadcast
half-duplex
ip address 10.2.2.2 255.255.255.0
half-duplex
router eigrp 100
redistribute bgp 65512
network 10.0.0.0
distance 200 0.0.0.0 255.255.255.255
router bgp 65512
no synchronization
neighbor 196.202.232.63 remote-as 65512
ip classless
RTC
interface Loopback0
ip address 172.16.1.1 255.255.255.0
interface Loopback1
ip address 1.1.1.1 255.255.255.0
no ip address
shutdown
half-duplex
ip address 10.2.2.3 255.255.255.0
half-duplex
router eigrp 100
network 1.0.0.0
network 10.0.0.0
network 172.16.0.0
no auto-summary
There are show ip route on RTC:
Gateway of last resort is not set
1.0.0.0/24 is subnetted, 1 subnets
C 1.1.1.0 is directly connected, Loopback1
172.16.0.0/24 is subnetted, 1 subnets
C 172.16.1.0 is directly connected, Loopback0
10.0.0.0/24 is subnetted, 1 subnets
C 10.2.2.0 is directly connected, Ethernet0/1
No redistribution.
Please help me, what is the problem ??
Best regards
Can you do a "show ip bgp" on RTB to verify that routes from RTA are received via BGP. If not, make sure that RTA is originating the routes in BGP.
Hope this helps,
The is "show ip bgp " result:
RTB#show ip bgp
BGP table version is 3, local router ID is 196.202.232.65
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*>i195.24.14.0 196.202.232.63 0 100 0 i
*>i196.202.232.0 196.202.232.63 0 100 0 i
The issue is that by default iBGP routes are not redistributed in the IGP. You can use "bgp redistribute-internal" command under the router bgp process to change this default behavior.
Please refer to the following URL for more information about this command:
Hope this helps,
Thank you Hritter.
Now the routes can be redistribute from bgp to eigrp.
But i don't see the url you to me.
Best regards.
Can you access this URL:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123cgcr/iprrp_r/ip2_a1g.htm#wp1057321
Hope this helps,
Sorry I forgot the URL. Here it is.
