redistribute rip into ospf
i_hanu
Hi!
Please help me, where am I wrong?
I don't receice on BUH03 routes from BUH02 and on BUH02 routes from BUH03.
I attached a map photo.
BUH03
router ospf 2 vrf REG
redistribute bgp 100 subnets
network 172.16.51.0 0.0.0.255 area 0
router ospf 1
network 10.0.0.28 0.0.0.3 area 0
router bgp 100
bgp log-neighbor-changes
address-family ipv4 vrf REG
redistribute ospf 2
exit-address-family
IOU2#show ip route vrf REG
Routing Table: REG
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override
Gateway of last resort is not set
172.16.0.0/16 is variably subnetted, 3 subnets, 2 masks
R 172.16.32.0/24 [120/1] via 172.16.52.2, 00:00:21, Vlan50
C 172.16.52.0/24 is directly connected, Vlan50
L 172.16.52.1/32 is directly connected, Vlan50
BUH02
router rip
network 172.16.0.0
no auto-summary
version 2
exit-address-family
router bgp 100
redistribute rip
exit-address-family
BUH03#show ip route vrf REG
Routing Table: REG
172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 172.16.51.0/24 is directly connected, Vlan50
L 172.16.51.1/32 is directly connected, Vlan50
15 Replies 15
mitchelhorstone
To redistribute routes from RIP (Routing Information Protocol) into OSPF (Open Shortest Path First), you need to configure redistribution on the router running OSPF. Here's a generic example of how you might do this in a Cisco environment:
bashCopy code
router ospf [process-id] redistribute rip subnets
In this example:
  • router ospf [process-id]: Enter OSPF configuration mode, replacing [process-id] with the OSPF process ID.
  • redistribute rip subnets: This command redistributes RIP routes into OSPF, and subnets specifies that the subnet information should also be redistributed.
Keep in mind that the exact commands may vary depending on your specific router model and software version. Additionally, redistribution should be carefully planned to avoid routing loops and other issues, so it's important to understand the implications of redistributing routes between different routing protocols.
Always consult the documentation specific to your router platform and software version for accurate and detailed instructions.......
