Redistribute Static options
saquib.tandel
I got remote offices connected to our DataCenter some via MPLS and some via VPN terminated on Cisco ASA. I am running OSPF on LAN and BGP for MPLS sites. To have reachability to VPN remote offices  I added 'redistribute static in OSPF' and to have rechability to sites connected via metro link i added 'redistribute connected'
router ospf 1
network 10.10.0.0 0.0.0.255.255 area 0
redistribute static
ip route 0.0.0.0 0.0.0.0 ASA
ip route 10.10.150.0 255.255.255.0 MPLS
ip route10.10.155.0 255.255.255.0 WAN_RTR
Ip route 10.10.157.0 255.255.255.0 ASA
ip route 192.168.12.0 255.255.255.0 ASA
Are there better ways of doing the config then above.
I also need restrictive access to Training Center i.e some remote office  passing  MPLS cloud can access Training Center site and some remote vpn office  passing ASA can access Training Center site
ST
NickNac79
Hi ST,
You haven't said where your OSPF neighbors are, are the ASA, WAN router or MPLS routers OSPF neighbors, and are they under your control?
Assuming that your OSPF neighbors are connected only to your Core switch (and not shown in the diagram) I would do it this way:
router ospf 1
  default-information originate
  passive-interface default
  no passive-interface (repeat as necessary)
  redistribute static subnets metric-type 1
ip route 10.10.157.0 255.255.255.0 ASA
Nick
5 Replies 5
NickNac79
Hi ST,
router ospf 1
Nick
Hi Nick
I got 15 offices in the same building of DataCenter some are uplinks and some are trunk ports, those sites are part of ospf
Looking at the above config not sure if I will be still able to restrict one remote office behind mpls to reach training_center site as per above topology
thanks
ST
you can restrict user access by using ACL's, prefix-lists etc..depends on how your configuration is setup etc. but in short , its doable
Kishore  can you give example as per your post. my sample config you can view above in the post
Hi ST,
You just need a basic ACL on your Core Switch interface facing the MPLS router...  e.g.
ip access-list extended ACL_MPLS_IN
  deny ip 10.10.150.0 0.0.0.255 10.10.155.0 0.0.0.255
  permit ip any any
int g0/0
  ip access-group ACL_MPLS_IN in
This is just a very simple example - you can find more information here
Hope that helps,
Please rate any posts you find helpful.
Nick
