05-13-2005 10:52 AM - edited 03-03-2019 09:33 AM
I have an internet router->pix->layer 3 switch scenerio. The internet router, pix, and layer 3 switch are running OSPF so I can learn the WAN route. I also have EIGRP on the l3 switch for other corporate switches and sites. I tried to redistribute OSPF into EIGRP so I can set a gateway for the WAN route and have a backup one. I'm not seeing the OSPF routes in any of the other L3 switches or routers running the same EIGRP. Any suggestions?
05-13-2005 11:28 AM
Have you configured a "default-metric" statement in your EIGRP configuration. Redistribution won't work without it.
Please refer to the following URL for more information on that configuration command:
Hope this helps,
05-13-2005 04:14 PM
Thanks. In this case with OSPF from a bonded T1, what would be wise default metrics to use for EIGRP. EIGRP is mostly runnung on a L3 switched infastructure. Thanks
05-13-2005 07:51 PM
It doesn't make a difference if you only have one redistribution point.
I have always used the same combinaison:
default-metric 10000 10 255 1 1500
Hope this helps,
