11-27-2021
07:29 AM
- last edited on
11-27-2021
11:45 PM
by
Translator
I have a one lab environment. I trying to redistribute rip and ospf. Rip network inject from 2 sides routers 3 and 4 , I applying the Route-map to TAG the injected routes from both.But I figure out some OSPF Routes (10.10.10.0 and 192.168.25.0) networks also injected back in to OSPF network by RIP. You can on see my router 3 and 4 also getting the same routes from the Rip. See attached pictures (highlighted networks getting from Rip) and my configurations.
Please answer the followings:
1. What are the reason?
2. How to handle it.
hostname R1
interface Loopback1
ip address 1.1.1.1 255.255.255.0
interface FastEthernet0/0
ip address 192.168.12.1 255.255.255.0
duplex half
router rip
version 2
offset-list 0 out 5
network 1.0.0.0
network 192.168.12.0
no auto-summary
hostname R2
ip address 192.168.12.2 255.255.255.0
duplex full
interface FastEthernet1/0
ip address 192.168.23.2 255.255.255.0
duplex full
speed auto
interface FastEthernet2/0
ip address 192.168.24.2 255.255.255.0
duplex full
speed auto
router rip
version 2
network 192.168.23.0
network 192.168.24.0
no auto-summary
hostname R3
interface Loopback1
ip address 10.10.10.1 255.255.255.0
ip address 192.168.34.1 255.255.255.0
duplex full
ip address 192.168.23.1 255.255.255.0
duplex full
speed auto
router ospf 1
router-id 3.3.3.3
redistribute rip subnets route-map TAGGING
network 10.10.10.0 0.0.0.255 area 0
network 192.168.34.0 0.0.0.255 area 0
router rip
version 2
redistribute ospf 1 metric 1 route-map TAGGING
no auto-summary
ip forward-protocol nd
no ip http server
no ip http secure-server
no cdp log mismatch duplex
route-map TAGGING deny 10
match tag 1234
route-map TAGGING permit 20
set tag 1234
hostname R4
interface Loopback1
ip address 192.168.25.1 255.255.255.0
ip address 192.168.34.2 255.255.255.0
duplex full
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/1
no ip address
shutdown
duplex auto
speed auto
ip address 192.168.24.1 255.255.255.0
duplex full
speed auto
router ospf 1
router-id 4.4.4.4
network 192.168.25.0 0.0.0.255 area 0
router rip
version 2
no auto-summary
no ip http server
match tag 1234
set tag 1234
Solved! Go to Solution.
11-27-2021 09:46 AM
Hi @libra_ali786 ,
You redistribution filtering configuration is fine. The behavior you are seeing with 192.168.25.0 and 10.10.10.0 is due to ospf advertising these prefixes as /32, which is the default when advertising the loopback interface ip address, regardless of the subnet mask configured on the loopback interface. You can change the default behavior by configuring "ip ospf network point-to-point" under the loopback interface. This should fix the issue.
11-27-2021 09:46 AM
Hi @libra_ali786 ,
11-27-2021 11:02 AM
Thank you very Much Sir.
