07-08-2021 02:30 AM
hi
can anybody help me with this issue
I am trying to redistribute the 192.168.1.1/32 into ospf
BGP in enabled on R1 and R2 only
all the settings are as default
I can see the route in R2's BGP table, but I can't see it in OSPF after redistribution
R1#show ip interface brief
GigabitEthernet0/0 10.123.1.1 YES manual up up
GigabitEthernet0/1 unassigned YES unset up up
GigabitEthernet0/2 unassigned YES unset up up
GigabitEthernet0/3 unassigned YES unset up up
Loopback0 192.168.1.1 YES manual up up
R1#show running-config | section router
router bgp 100
bgp log-neighbor-changes
network 192.168.1.1 mask 255.255.255.255
neighbor 10.123.1.2 remote-as 200
R2#show ip route bgp | begin Gateway
Gateway of last resort is not set
192.168.1.0/32 is subnetted, 1 subnets
B 192.168.1.1 [20/0] via 10.123.1.1, 00:13:01
R2#show ip interface brief
GigabitEthernet0/0 10.123.1.2 YES manual up up
GigabitEthernet0/1 10.24.1.2 YES manual up up
Loopback0 192.168.2.2 YES manual up up
R2#show running-config | section router
router ospf 1
redistribute bgp 200 subnets
network 10.24.1.2 0.0.0.0 area 0
router bgp 200
network 192.168.2.2 mask 255.255.255.255
neighbor 10.123.1.1 remote-as 100
R2#show ip route ospf | begin Gateway
10.0.0.0/8 is variably subnetted, 6 subnets, 2 masks
O 10.35.1.0/24 [110/3] via 10.24.1.4, 00:11:33, GigabitEthernet0/1
O 10.45.1.0/24 [110/2] via 10.24.1.4, 00:11:33, GigabitEthernet0/1
Solved! Go to Solution.
07-08-2021 03:54 AM
You won't see it in R2's routing table because R2 is using the BGP route for 192.168.1.1/32 which it redistributes into OSPF.
To see if the redistribution is working check the routing table on R4, for example, and you should see it there.
Jon
07-08-2021 08:37 AM - edited 07-08-2021 11:27 AM
after recheck and see the topology,
R1-R2,
R2 will be select this prefix as best path and install it into routing table,
R2 will redistribute it into OSPF which will resend it to other routers, so check in other router not R2 routing table.
07-08-2021 03:54 AM
Jon
R1-R2,
07-08-2021 12:20 PM
yes it's really as you said
R4#show ip route ospf | begin Gateway
10.0.0.0/8 is variably subnetted, 5 subnets, 2 masks
O 10.35.1.0/24 [110/2] via 10.45.1.5, 09:11:03, GigabitEthernet0/0
O E2 192.168.1.1 [110/1] via 10.24.1.2, 09:03:51, GigabitEthernet0/1
192.168.2.0/32 is subnetted, 1 subnets
O E2 192.168.2.2 [110/1] via 10.24.1.2, 09:00:40, GigabitEthernet0/1
Thanks for your help
