06-30-2024 03:49 AM - edited 06-30-2024 03:50 AM
I have a N7K which is configured with multiple VDC (VDC-DIST and VDC-CORE). i have EIGRP routing activated on the two VDC and the neighboring is working fine. I am also able to redistributed direct network connected from the DIST to the CORE. But the redistribution of static routes created on DIST is not working. The CORE don't see those routes via the EIGRP. Can someone help me please, i am new on NX-OS
Configuration of DIST:
ip prefix-list REDISTRIBUTION seq 5 permit 0.0.0.0/0 le 32
route-map redist-static permit 10
match ip address prefix-list REDISTRIBUTION
redistribute direct route-map redist-static
redistribute static route-map redist-static
router eigrp VIN
autonomous-system 1
router-id 0.0.0.230
address-family ipv4 unicast
ip route 10.254.0.152/30 10.101.222.100
The route 10.254.0.152 is not seen from the CORE.
Solved! Go to Solution.
07-04-2024 12:32 AM
Hello MHM,
Sorry for late. Yes i tested it and it was good. I want to thank you for all the support you gave to me.
It is really kind. Thank you very much.
07-01-2024 01:00 PM
lost connection this can due to behave of EIGRP which is different of other IGP like OSPF when we use redistribute static the eigrp redistribute static and default
MHM
07-01-2024 12:22 PM
Hello @malickmbaye
Glad to hear you have a resolution, and thank you for the feedback.
