Redistribution
The_guroo_2
Level 2
Level 2
Guys just a quick one.........when we do redistribution like from OSPF.....to eigrp...how we gonna calculate the metric....what are the factors that we will keep in mind to put the values like on of our routers have follwoing
router eigrp XX
redistribute ospf 12 metric 100000 1000 255 1 1500
on which based we will calculate these values ....can someone please tell me the easiest way....regards
Giuseppe Larosa
Hello Khan,
actually you need to provide a seed metric when redistributing a dynamic protocol into EIGRP.
So the actual values are important only if you have multiple redistribution points and you want to have a preferred exit point from EIGRP domain
however the parameters are:
first Bandwidth in kbps = 100 Mbps
second delay in tens of microsec 10000 microsec = 10 ms
third reliability (255/255 good)
fourth is load (1/255 empty link)
fifth is MTU (1500)
the idea is to take the parameters of the router interface in OSPF 12 domain that can be a FE 100Mbps in this case
With default K values only BW and delay are used to calculate the seed metric and MTU is inserted in its own field in the data structure that represents the external route.
Hope to help
Giuseppe
