Reg:2821
vasuramnet
Dear Experts,
Iam planing to implement point to multipoint connectivity in central location i want ethernet failover and iam attaching the diagram also kindly go through that and suggest me the ip sceem and config examples.
srinivas.D
9246571397
Wilson Samuel
Level 7
Level 7
Hi Srinivas,
If all the Interfaces are configured properly and if you deploy Dynamic Routing, it will work properly.
However atleast I'm not clear where do you want the Ethernet Failover, please elaborate.
Wilson Samuel
Dear samuel,
Thanks for ur reply .i want a ethernet failover in MCP(itwas mentioned on diagram)mcp is head office inthat i want link failover and ethernet failover.
plz send me the sample config.its anew setup iwant to plan for ip sceem.
regards
srinivas.D
9246571397
