reg:multilink
Dear sir,
whether the 4 HWIC serial ports are configured as ppp multilink
Using 2821 and 2811 routers individually.
Plz conform
srini
durga_suji
I do not think there should be any problems... Cisco 2800 series supports the 4HWIC hardware connectivity and it can be used for multilink.
you can also check this:
http://www.cisco.com/cdc_content_elements/flash/nextgen/webversion/2800/kaon/2801/index.html
