Regarding IBGP
sachinmhatre011
Hello All,
I have two routers connected and running IBGP between two of them and I am able to ping each other.
But later I replace one of the router with same configuration and now I am unable to ping the other router, the replaced new router is of same vendor.
May I know why this is happening.
10 Replies 10
Francesco Molino
Do you see a correct peering between them?
If your routers are directly connected to mount iBGP sessions, you can't ping the direct connected interface, is that right?
Could you explain a little bit more your issue and maybe a quick sketch would help.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Same configuration is done on the new router but unable to ping the other device.
I understand that point however what do you mean by unable to ping:
 - Ping connected interfaces ?
 - Is there a router in the middle or they are directly connected with a cable?
- Does iBGP session came out
Even you copied the configuration, the issue could be physical, or logical.
In order to help, I need to understand a bit more your design, configuration
Francesco
Actually this was the question asked to me in an interview at Infosys, so I wanna know the answer of it .
Refer to the Cisco live presentation:
https://www.ciscolive.com/online/connect/sessionDetail.ww?SESSION_ID=83643&backBtn=true
It shows show to troubleshoot peering down issues.
Hope this helps.
Vinit
--Vinit
I am trying to Ping connected interfaces and they are directly connected with a cable
Ok if you are trying to ping the other end device from the cable and you insure that subnet is correctly configured, you have to troubleshoot from layer 1.
- Is it Ethernet cable or fiber?
- Does cable is ok?
- If SFP are used for fiber and/or ethernet, does the SFP is ok?
- Speed/Duplex configuration from interface
- If physical layer is ok then move on next steps:
- Switch in between?
- Route to null (sometimes on exam they love doing such stuff....)
- ACL,....
But if you have trust config that are exactly the same, the only issue could be physical or logical (interface missconfigured, shutdown,...)
The idea is to begin from layer 1 and going step by step.
Francesco
The reason for the issue can be a bad port or SFP (if you are using fiber).
One way to troubleshoot would be to perform a ping test to the connected device. If the connected device is a Cisco router, then you can run "show ip traffic | in echo" and see if the ECHO received counters and echo-reply sent counter are incrementing or not.
You can verify the same command on the problematic router and see if you are seeing the Echo sent counters and Echo-reply received counter incrementing.
Hope this helps.
Vinit
--Vinit
Thanks Vinit.
Support07
iBGP is it up now ?
Each router are directly connected ? or connected to the same LAN ?
if you can show us : show ip interface brief, show ip bgp summary of the both router it will be more easy to help you
TkR07_9393
