Regarding Terminations
ncnaveen_arasu
            HI Team,
In WAN point to point links if we terminate one end in etherport and other end in serial port for 2/8Mbps conectivity in the routers, wether will it work as both ends termination types are diffrent. What should be the encapsulation we need to use for this type of links.
PLease clarify.
Thanks & Regards,
Naveen
mahmoodmkl
Level 7
Level 7
is the service provider involved in this thn they will take of this
HI Mahmood, Thnaks for the reply,
ISP will take care of terminations. but in theoratical wether will it be feasible and will it work if both ends are diffrent terminations.
Naven
In practice it will not work if one end is Ethernet and the other end is serial. These are very different transport protocols and they do not inter-operate.
Rick
Rick
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
As Rick has noted, you can't directly connect different media technologies on the same physical link and have it work.  For example, even "pure" 100 Mbps FastEthernet won't inter-operate with "pure" 10 Mbps Ethernet.
If there is some device (or devices) "in the middle" that performs media conversion then you can use different media on the ends of a logical link.  ISPs often can provide the "in the middle" media conversion.
