Regarding Traceroute
praveencherala
Can any one explain me about the traceroute functionality.
why traceroute is limited to maximum of 30 hops ?
Please explain...........
Praveen Kumar Cherala
tony.henry_2
Praveen,
Please review the PDF.
http://www.cisco.com/application/pdf/paws/13730/ext_ping_trace.pdf
My reading tells me that 30 is an arbitrary number, I guess they (cisco programmers) figured after 30 hops you've got other problems.
If you still have problems understanding what traceroute is about then you may want to rephrase your question to highlight what you'd really like to know.
Tony
IMHO, traceroute is NOT limited to  maximum of 30 hops.
It's just a default value on Cisco routers.
See:
Router1# trace ip 10.10.10.10 ttl 1 ?
<1-255>  maximum ttl
So if you want, you can trace up to 255 hops.
The same in MS Windows:
C:\Documents and Settings\mk>tracert -h 255 www.cisco.com
HTH,
Milan
