Remote access with dual ISP
bramdj
Just configured an ASA 5510 to support dual ISP's with the "track" option.
Primary connection should be used for internet access and the secondary line for remote access (VPN). If primary link fails all traffic will be send out trough the secondary ISP.
Currenty the remote users can setup their session but are unable to access corporate LAN. Is this setup supported?
Bram
vkapoor5
Level 5
Level 5
Yes , that setup is supported and could you please specify what software release are you using in the ASA box ?
