Remote DHCP Server
alvergam39
Hello
I have Cisco 1841 router on a lan (192.168.0.254).
In the same Lan i have a Server (192.168.0.1) who is work as a DHCP Server.
Can you help me with router configuration ?
It will work as relay agent or what ?
Thank You
alvergam39 .
pkhatri
Level 11
Level 11
In order to relay DHCP requests out to this server, configure the folloowing under the other interfaces (the interfaces apart from the one to which the server is connected) of the router:
ip helper-address 192.168.0.1
Hope that helps - pls rate the post if it does.
Paresh
