removed
rgaudrault
removed
7 Replies 7
paolo bevilacqua
Can you rephrase that and maybe attach a digram ?
I have update, thanks for any help you can provide.
hobbe
Level 7
Level 7
I do not think that you can do that with an etherchannel.
shure you can do load balancing and so on but i do not think the etherchannel will like an encryption engine in one link of the the etherchannel and one in another.
To be honest this looks like recipe for disaster.
If i were you and I needed an encrypted link I would look into 802.1ae and the new breed of switches that is coming up.
good luck
MACSec is not end to end encryption, and that is what the customer requires.  This is an Ethernet encryptor that leaves the MAC header clear and encrypts layer 3 and above.    They are only using EtherChannel to allow quick recovery of a failed condition, not for the added bandwidth.   We may have to redesign to allow this network to function.
Ok fair enough.
You are absolutely right it is not end to end encryption.
Can you paste the make and model of your encryption devices ?
it might make things easier to find information on how they handle things.
Good luck
removed
hobbe
Level 7
Level 7
You say that you want to use it for "failover purposes"
Maybe you can use link state tracking ?
I can not find how they are working or how they are configured and you mentioned that you needed a link for some information like key exchange and stuff.
If nothing else I am shure you will be able to do some things with TCL to make it work.
