reservation through RIP
snowbarsss
I need to connect a remote office (branch_1) with the main (router_1) using the reservation. One side looks strontium in another ISP (upper cloud, it will give a transparent data), a second arm looks in our network (low cloud). In our channel uses RIP. Give advice on how to make hot backups on a remote branch office, when 2 interface in ripping? IMPORTANT that was the main link to the ISP, and our cloud reserve.
I think that you can simply change the metric of RIP on our interface (such as adding hops), but have not found how to do it.
P.S. All models and names irrelevant, the main thing needed is a principle of action
Jose Jara
Level 3
Level 3
Hello Andrey,
ir order to change the metric of RIP you may use an offset-list:
offset-list 1 in serial1/0 2
1 - access-list to specify the prefixes to apply the offset, using 0 will apply to all networks
2- the number of hops added to change the metric
Best Regards,
Jose.
