3847
eric
Beginner
Reserve outbound bandwidth for VoIP
Greetings,
I have a Cisco 877 on an ADSL connection.  QoS isn't doing the trick -- I need to reserve 200 meg or so of my outbound (upstream) bandwidth for VoIP to end complaints about voice quality.
Can anyone point me to an example of how to classify SIP, RTP, IAX, and Skype traffic and put a rate limit on anything that doesn't fall into that category?  The VoIP phones also are in their own IP range on the LAN side if that would make things easier...or I could even connect them into a specific port on the internal switch in the router.
Advice appreciated!
Eric
2 ACCEPTED SOLUTIONS
Firstly - I do not mark and prioritise in the same place/policy.
I would mark the VoIP traffic on INGRESS from the LAN
class-map match-any VoIP
match  dscp ef
match protocol sip
match protocol skype
match protocol custom-01
match protocol rtp audio
match protocol rtp video
policy-map Mark_VoIP_LAN
class VoIP
set dscp ef
Int x/x Directly connected LAN interface to VoIP Devices
service-policy input Mark_VoIP_LAN
Then change
policy-map SDM-QoS-Policy-3
class VoIP
  set dscp ef (remove this - already done) on LAN policy above)
  priority xxx (actual number in Kbps you want) not the percentage of the interface.
class class-default
  fair-queue
  random-detect dscp-based *** WRED***
HTH>
Missing:-
interface Dialer0
service-policy output SDM-QoS-Policy-3
Other than that - looks OK.
9 REPLIES 9
andrew.prince
Advocate
Eric,
200Mbs? are you seirous? I have a central site location with 300+ people using VoIP phones running on a 10mbs line?
QoS probably is not working for you - as you may not have deployed it correctly.  Remember - Classify & Mark = congestion avoidance.
HTH>
Any thoughts on what I did wrong here?
I'm new to QoS and used SDM to create this.  The major problem I'm having is with SIP/RTP.
match  dscp ef
match protocol sip
class-map match-any SDM-Transactional-1
match protocol citrix
match protocol finger
match protocol notes
match protocol novadigm
match protocol pcanywhere
match protocol secure-telnet
match protocol sqlnet
match protocol sqlserver
match protocol ssh
match protocol telnet
match protocol xwindows
class-map match-any SDM-Signaling-1
match protocol h323
match protocol rtcp
match protocol sip
class-map match-any SDM-Routing-1
match protocol bgp
match protocol eigrp
match protocol ospf
match protocol rip
match protocol rsvp
class-map match-any SDM-Voice-1
class-map match-any SDM-Management-1
match protocol dhcp
match protocol dns
match protocol imap
match protocol kerberos
match protocol ldap
match protocol secure-imap
match protocol secure-ldap
match protocol snmp
match protocol socks
match protocol syslog
class-map match-any Inbound-VoIP
match  dscp ef
match protocol sip
policy-map SDM-QoS-Policy-2
class Inbound-VoIP
  set dscp ef
class class-default
   police cir 4500000
     conform-action transmit
     exceed-action drop
     violate-action drop
class VoIP
  set dscp ef
  priority percent 20
class class-default
  fair-queue
policy-map SDM-QoS-Policy-1
class SDM-Voice-1
  set dscp ef
  priority percent 75
class SDM-Signaling-1
  set dscp cs3
class SDM-Routing-1
  set dscp cs6
class SDM-Management-1
  set dscp cs2
class SDM-Transactional-1
  set dscp af21
class class-default
   police cir 375000
     violate-action drop
  bandwidth remaining percent 20
interface Dialer0
ip address negotiated
ip access-group 103 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip nbar protocol-discovery
ip flow ingress
ip flow egress
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer idle-timeout 0
dialer persistent
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username xxxxxxxxxxxxx xxxxxxxxxxxxx xxxxxxxxxxxxxxxxx
service-policy input SDM-QoS-Policy-2
match  dscp ef
match protocol sip
class VoIP
set dscp ef
Then change
class VoIP
class class-default
  fair-queue
HTH>
Thanks.
Would that mark all inbound traffic on the LAN interface as ef, or only if it also met the class-map ?
Only for traffic that meets the criteria stated in the class map, any other traffic would not be marked.
Thank you very much!  Does this look right?  Anything I should remove?
match  dscp ef
match protocol sip
match protocol ssh
match protocol h323
match protocol rtcp
match protocol sip
match protocol bgp
match protocol ospf
match protocol rip
match protocol rsvp
match protocol dhcp
match protocol dns
match protocol imap
match protocol ldap
match protocol snmp
match  dscp ef
match protocol sip
class Inbound-VoIP
  set dscp ef
class class-default
   police cir 4500000
     exceed-action drop
     violate-action drop
class VoIP
  priority 200
class class-default
  fair-queue
class SDM-Voice-1
  set dscp ef
  priority percent 75
  set dscp cs3
class SDM-Routing-1
  set dscp cs6
  set dscp cs2
  set dscp af21
class class-default
   police cir 375000
     violate-action drop
class VoIP
  set dscp ef
interface Null0
no ip unreachables
interface ATM0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.2 point-to-point
no ip redirects
no ip unreachables
no ip proxy-arp
pvc 0/35
  oam-pvc manage
  pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address 10.0.0.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip inspect sdm_ins_in_100 in
ip route-cache flow
ip tcp adjust-mss 1412
interface Dialer0
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1492
ip flow ingress
ip flow egress
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer persistent
dialer-group 1
no cdp enable
ppp pap sent-username xxxxxxxxxxxxxxxxxxxxxxxxx
Missing:-
interface Dialer0
Thank you very much Andrew!
For anyone else who finds this thread in the future, I also just learned that despite the integrated DSL interface, it appears that the Cisco 877 doesn't "know" how fast the DSL link is. It appears to you need to manually tell it:
interface Dialer0
bandwidth 768
bandwidth receive 5000
I expect I'll undoubtedly have to tweak these downward until I achieve VoIP nirvana.
Thanks again!
eric
Beginner
Mistyped...should have read "200kbps"
