Restore switch backup
darp27609679
Hi, I want to restore a backup from c2960 to other one.
Why is recommended to remove any security commands, like AAA?
Hi Damian,
If your both the swithes (c2960 and other one) in under same network and both are needs to be communicated with same AAA server (TACACS/RADIUS) authontication, then you can go ahead with AAA config too for the restoration, but only you need to make sure about your other switch interface/gateway IP's,
KodandaRao, - Pls rate useful posts.
Hi Damian,
darp27609679
Thanks!
