RIB failure in sh ip bgp
mohAmed khAdr
Beginner
Beginner
All,
I am running a confed lab.....only bgp...no any igp..
on sh ip bg I find 1 rib failure...I did a sh ip bg rib and I got this:
R1_AS100#sh ip bg rib
Network                          Next Hop                      RIB-failure   RIB-NH Matches
201.199.25.160/27        201.199.25.178              Higher admin distance              n/a
R1_AS100#
Here's the whole sh list:
R1_AS100#sh ip bg
BGP table version is 14, local router ID is 10.10.100.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale  Origin codes: i - IGP, e - EGP, ? - incomplete
    Network                     Next Hop            Metric LocPrf Weight Path
*> 10.10.100.1/32              0.0.0.0                  0         32768 i
*> 10.10.130.1/32             201.199.25.178       0         500 i
*> 10.10.140.1/32             201.199.25.178                         0 500 i
*> 10.10.150.1/32             201.199.25.178           0             0 500 i
*> 130.33.255.0/27           201.199.25.178                         0 500 i
*> 140.44.255.0/26           201.199.25.178                         0 500 i
*> 150.55.255.144/28        201.199.25.178           0             0 500 i
*> 172.20.1.0/28               201.199.25.178                         0 500 ?
*> 192.168.1.0/30             201.199.25.178                         0 500 ?
*> 192.168.1.4/30             201.199.25.178           0             0 500 ?
*> 201.199.24.0/25          0.0.0.0                  0         32768 i
r> 201.199.25.160/27       201.199.25.178           0             0 500 ?
R1_AS100#sh ip int brie
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            201.199.25.179  YES manual up                    up
FastEthernet0/1            201.199.24.1    YES manual up                    up
Loopback0                  10.10.100.1     YES manual up                    up
R1_AS100#
What higher AD ?
Anyone with better explanation?
Thx.
mohamed
John Blakley
Mohamed,
RIB failures like this generally indicate that it's receiving a better path by some other means. You're advertising this network from another router, but it can't put this route in the table because it has a higher administrative distance than your locally connected network.
HTH,
John
HTH, John *** Please rate all useful posts ***
John Blakley
Mohamed,
HTH,
John
John,
Thx...spot on! it's connected...it has  distance 0, metric 0
Thx again
Nandan Mathure
Beginner
Beginner
Hi!
Also paste output for : show ip route 201.199.25.160 & show ip bgp 201.199.25.160
Nandan
