RIP 1 & RIP2
CSCO10320953
What is the main difference between RIP-v2 and RIP-v1?
subnet mask information is contained in updates
use of the Bellman Ford algorithm
support for ATM
use of triggered updates
sourabhagarwal
Level 4
Level 4
subnet mask information is contained in updates should be the right one as RIPv1 is classfull while RIPv2 is classless routing protocol.
icabrera
Level 4
Level 4
Hi, two of these are correct:
subnet mask information is contained in updates and use of triggered updates, these are for v2
rajinikanth
Level 3
Level 3
Use of subnet mask in updates
and
Use of triggered updates are two major difference between RIPv1 and RIPv2
Raj
Use of 224.0.0.9 multicast address for diffusing updates in place of 255.255.255.255 broadcast address.
Cheers,
