RIP coverage
fhameed21
Hello everyone
I've a question.
Router A is connected to B
Router B is connected to C
Router C is connected to A
Using RIP i would like my router A to take route B to reach destination C
It should not use the obvious path A-C to reach C directly.
Static routing , access list and other routing protocols are not allowed.
How to achieve the result??
Fahad
Harold Ritter
You can use an offset-list on router A interface to router C to increase the metric for updates received from router C.
This should cause router A to prefer router B to reach destinations connected to router C.
For more information on the offset-list, please refer to the following URL:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123cgcr/iprrp_r/ip2_o1g.htm#wp1036466
Hope this helps,
