RIP w/ Unnumbered Interface Issue
jas2061461
R6 - R7 via Serial link.  R6 is installing updates from R7 in its R.T.  R7 is receiving updates from R6 but not installing the routes in the RIP database or R.T.  Any ideas what might be wrong?
R6:
version 1
timers basic 30 180 0 240
passive-interface Loopback99
network 192.168.1.0
network 192.168.2.0
default-metric 13
no auto-summary
no valid-update-source
interface Serial0/0
ip unnumbered Loopback99
ip rip send version 2
ip rip receive version 2
encapsulation ppp
ip address 192.168.2.5 255.255.255.252
end
R7:
version 2
no validate-update-source
passive-interface default
no passive-interface FastEthernet0/0
no passive-interface Serial0/0
no passive-interface Serial0/1
network 10.0.0.0
network 192.168.1.0
network 192.168.2.0
no auto-summary
interface Serial0/0
ip address 192.168.2.2 255.255.255.252
encapsulation ppp
clock rate 64000
no fair-queue
R6 Debug:
*Mar  1 02:11:29.615: RIP: sending v2 update to 224.0.0.9 via Serial0/0 (192.168.2.5)
*Mar  1 02:11:29.615: RIP: build update entries
*Mar  1 02:11:29.615:   10.0.0.0/8 via 0.0.0.0, metric 3, tag 0
*Mar  1 02:11:29.615:   40.0.0.0/8 via 0.0.0.0, metric 13, tag 0
*Mar  1 02:11:29.615:   172.16.0.0/16 via 0.0.0.0, metric 2, tag 0
*Mar  1 02:11:29.615:   192.168.1.0/24 via 0.0.0.0, metric 1, tag 0
*Mar  1 02:11:29.619:   192.168.2.4/30 via 0.0.0.0, metric 1, tag 0
*Mar  1 02:13:35.919: RIP: received v2 update from 192.168.2.2 on Serial0/0
*Mar  1 02:13:35.919:      0.0.0.0/0 via 0.0.0.0 in 13 hops
*Mar  1 02:13:35.919:      2.2.2.2/32 via 0.0.0.0 in 3 hops
*Mar  1 02:13:35.919:      4.4.4.4/32 via 0.0.0.0 in 3 hops
*Mar  1 02:13:35.919:      10.0.0.0/24 via 0.0.0.0 in 3 hops
*Mar  1 02:13:35.919:      10.1.0.0/24 via 0.0.0.0 in 9 hops
*Mar  1 02:13:35.923:      10.2.0.0/24 via 0.0.0.0 in 4 hops
*Mar  1 02:13:35.923:      10.3.0.0/24 via 0.0.0.0 in 4 hops
*Mar  1 02:13:35.923:      10.4.0.0/24 via 0.0.0.0 in 3 hops
*Mar  1 02:13:35.923:      10.100.0.0/29 via 0.0.0.0 in 2 hops
*Mar  1 02:13:35.923:      10.100.0.8/30 via 0.0.0.0 in 2 hops
*Mar  1 02:13:35.923:      10.100.0.32/30 via 0.0.0.0 in 1 hops
*Mar  1 02:13:35.927:      10.100.0.34/32 via 0.0.0.0 in 1 hops
*Mar  1 02:13:35.927:      172.16.0.0/24 via 0.0.0.0 in 2 hops
R7 Debug:
*Mar  1 02:12:41.671: RIP: sending v2 update to 224.0.0.9 via Serial0/0 (192.168.2.2)
*Mar  1 02:12:41.671: RIP: build update entries
*Mar  1 02:12:41.671:   0.0.0.0/0 via 0.0.0.0, metric 13, tag 0
*Mar  1 02:12:41.671:   2.2.2.2/32 via 0.0.0.0, metric 3, tag 0
*Mar  1 02:12:41.671:   4.4.4.4/32 via 0.0.0.0, metric 3, tag 0
*Mar  1 02:12:41.671:   10.0.0.0/24 via 0.0.0.0, metric 3, tag 0
*Mar  1 02:12:41.671:   10.1.0.0/24 via 0.0.0.0, metric 9, tag 0
*Mar  1 02:12:41.675:   10.2.0.0/24 via 0.0.0.0, metric 4, tag 0
*Mar  1 02:12:41.675:   10.3.0.0/24 via 0.0.0.0, metric 4, tag 0
*Mar  1 02:12:41.675:   10.4.0.0/24 via 0.0.0.0, metric 3, tag 0
*Mar  1 02:12:41.675:   10.100.0.0/29 via 0.0.0.0, metric 2, tag 0
*Mar  1 02:12:41.675:   10.100.0.8/30 via 0.0.0.0, metric 2, tag 0
*Mar  1 02:12:41.675:   10.100.0.32/30 via 0.0.0.0, metric 1, tag 0
*Mar  1 02:12:41.679:   10.100.0.34/32 via 0.0.0.0, metric 1, tag 0
*Mar  1 02:12:41.679:   172.16.0.0/24 via 0.0.0.0, metric 2, tag 0
*Mar  1 02:12:41.679:   172.16.2.0/24 via 0.0.0.0, metric 3, tag 0
*Mar  1 02:12:41.679:   172.16.3.0/24 via 0.0.0.0, metric 3, tag 0
*Mar  1 02:12:41.679:   172.16.4.0/24 via 0.0.0.0, metric 2, tag 0
*Mar  1 02:12:41.679:   172.16.5.0/24 via 0.0.0.0, metric 3, tag 0
*Mar  1 02:14:58.139: RIP: received v2 update from 192.168.2.5 on Serial0/0
*Mar  1 02:14:58.139:      10.0.0.0/8 via 0.0.0.0 in 3 hops
*Mar  1 02:14:58.139:      40.0.0.0/8 via 0.0.0.0 in 13 hops
*Mar  1 02:14:58.139:      172.16.0.0/16 via 0.0.0.0 in 2 hops
*Mar  1 02:14:58.139:      192.168.1.0/24 via 0.0.0.0 in 1 hops
*Mar  1 02:14:58.139:      192.168.2.4/30 via 0.0.0.0 in 1 hops
Does anyone know why R6 is installing the routes in its routing table,  but R7 is not?  I have looked through several (reference) guides and  havn't seen anything address this issue.  R7 is not installing any routes via R6 in its databse.  I tried using the neighbor commands on both routers, but still no luck.  R7 CAN ping 192.168.2.5 - the next-hop ip used to reach R6's networks.  I am assuming the issue is with the unnumbered interface w/ RIP, but I see no errors in the debug.
John Blakley
Do you have a diagram? The p2p connection that you're showing above isn't on the same network, so I'm assuming that you have something in between if you can ping them. 192.168.2.0/30 isn't on the same network as 192.168.2.4/30, but you said that you can ping between the 2.
HTH, John *** Please rate all useful posts ***
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094e8d.shtml
Based on the documentation's example, an unnumbered interface can reference an IP address that is on a different subnet, yet still communicate between an adjacent router and exchange updates.  The only portion of the diagram that I am having issues with is the communication between R6 and R7.  These links are directly connected. To make tshooting easier, I shutdown all interfaces besides R6/R7's Serial 0/0.
The topology is R6 ---- R7.  R6's unnumbered has 192.168.2.5/30 and R7 has 192.168.2.2/30. IE Different subnets.R6 is redistributing a 40.0.0.0/8 route w/ a metric of 13.  R7 is using "default-information originate" to create a quad zero route w/ a metric of 13.  R6 has installed the 0.0.0.0 to R7 via 192.168.2.2, yet R7 has not installed the 40.0.0.0/8.
R7's debug of rip events:
*Mar  1 00:02:47.919: RIP: received v2 update from 192.168.2.5 on Serial0/0
*Mar  1 00:02:47.919:      40.0.0.0/8 via 0.0.0.0 in 13 hops
*Mar  1 00:02:47.919:      192.168.2.4/30 via 0.0.0.0 in 1 hops
*Mar  1 00:04:19.455: RIP: sending v2 update to 224.0.0.9 via Serial0/0 (192.168.2.2)
*Mar  1 00:04:19.455: RIP: build update entries
R7 is not even placing the 40.0.0.0 in its database and therefore not being installed in the R.T.:
R7(config-if)#do sh ip rip da
0.0.0.0/0    auto-summary
0.0.0.0/0    redistributed
    [13] via 0.0.0.0,
192.168.2.0/24    auto-summary
192.168.2.0/30    directly connected, Serial0/0
192.168.2.5/32    directly connected, Serial0/0
R7 is not using validate-update-source.  IE There is no disregarding of those routes.
After changing R6 to be on the same subnet, changes were made on the loopback, R7 is still not installing the route:
R6#sh ip int s0/0
Serial0/0 is up, line protocol is up
  Interface is unnumbered. Using address of Loopback99 (192.168.2.1)
R6#sh ip int lo99
Loopback99 is up, line protocol is up
  Internet address is 192.168.2.1/30
R7#
*Mar  1 00:13:34.319: RIP: received v2 update from 192.168.2.1 on Serial0/0
*Mar  1 00:13:34.319:      40.0.0.0/8 via 0.0.0.0 in 13 hops
*Mar  1 00:13:34.319:      192.168.2.0/30 via 0.0.0.0 in 1 hops
R7#show ip route 40.0.0.0
% Network not in table
It appears to be an issue with RIP and unnumbered interfaces.  Does anyone recognize an issue, or know the circumstances which RIP must apply to be compatible with an Unnumbered interface?
Darnit!  Found I was deny anything learned by R6.  I didn't post the filtering, because I thought there wasn't an issue with it  An hour of tshooting "down the drain"...guess I learned a lot more than I thought though...lol.
Answer:
R7:
router rip
distribute-list prefix INBOUND_FILTER gateway GATEWAY in
ip prefix-list INBOUND_FILTER seq 5 permit 0.0.0.0/0 le 32
ip prefix-list GATEWAY seq 5 permit 10.100.0.34/32
ip prefix-list GATEWAY seq 10 permit 192.168.1.1/32
ip prefix-list GATEWAY seq 15 deny 0.0.0.0/0 le 32
Thanks for posting back to the forum to tell us that you found the problem and what the problem was. This is very helpful.
You may think that you had an hour of troubleshooting down the drain. But you learned a valuable lesson and it seems to me that the hour was in fact productive time.
Rick
Rick
